10-16-2013, 06:54 AM | #1 |
Newbie Join Date: Sep 2011 Location: sweden
| best styrene thickness for building?
Hi, I was going to start to build some interior on my scx10 honcho, but I wonder what the best thickness to use on the styrene is when you build? Should I use .080" (2mm) or thicker/thinner? |
10-16-2013, 06:59 AM | #2 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
| Re: best styrene thickness for building?
I would use .40 |
10-16-2013, 08:07 AM | #3 |
ok, I'll try that out, thanks |
10-16-2013, 08:52 AM | #4 |
i use .60, but i agree anything in that range is perfect, you want it thick enough to get a good strong bond. too thin and it will be harder to keep straight/flat as well.
10-16-2013, 09:01 AM | #5 |
Kinda depends on what you are using the styrene for. I keep 0.020" - 0.080" on hand. Depends on if I need to be able to bend the piece or not. Or if I need the structural strength. But for an interior like others mentioned 0.040" or 0.060" will work. Depends on if you need to bolt, glue or attach other parts/pieces/stuff to it. I said depends alot. |
10-16-2013, 03:00 PM | #6 |
thanks for the advices I saw a clip with some easy how-to with styrene and I saw that they used ambroid PRO weld to glue the pieces together. It looked really easy to use this "glue", is their any cons with this or is there something much better? |
10-16-2013, 03:52 PM | #7 |
| Re: best styrene thickness for building? |
10-16-2013, 04:20 PM | #8 |
10-16-2013, 05:40 PM | #9 |
10-16-2013, 05:41 PM | #10 |
10-16-2013, 08:18 PM | #11 |
haha good catch! <----owned! |
10-17-2013, 04:28 AM | #12 |
Rock Crawler Join Date: Oct 2012 Location: Vermont
Just ordered some 0.040 and 0.060 from RPP Hobby with the rest of my order to try to make a back wall to a cab.
best styrene thickness for building? - Similar Threads | ||||
Styrene sheet thickness? | Playtime747 | RC4WD Trail Finder 2 | 4 | 08-08-2013 11:17 PM |
Thickness of styrene | meanbgreen | Newbie General | 0 | 09-21-2011 12:51 AM |
What styrene thickness to use? | scrapen | Paint and Body | 6 | 09-18-2011 08:01 PM |
Styrene thickness? | Bestdallasfan6 | Paint and Body | 2 | 10-12-2008 11:24 PM |
styrene thickness? | Squadfer | Newbie General | 4 | 06-27-2008 04:44 PM |
