11-15-2013, 09:10 AM | #1 |
Rock Crawler Join Date: Nov 2011 Location: Omaha, Nebraska
| how to remove new bright from windshield
I have a new bright jk and i want to know if there is a way to get the words new bright off the windshield. Any suggestions? Thanks in advance, Kenneth |
11-15-2013, 09:58 AM | #2 |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
| Re: how to remove new bright from windshield
Is it a decal or is it painted on?
11-15-2013, 10:00 AM | #3 |
I think its painted
11-15-2013, 10:05 AM | #4 |
If its a decal peel it off then use some lighter fluid to remove the gum left behind. If its painted on try some brake fluid, test it on a spot first to make sure it doesn't fog up the plastic. Don't rub too hard either or it may haze the plastic. |
11-15-2013, 10:10 AM | #5 |
Ok will give that a shot will let you know what happens
11-15-2013, 11:12 AM | #6 |
Rock Crawler Join Date: Jul 2011 Location: USA
Try some "sticker shock" or "Goo Gone", ive used it in the past and it works great, doesnt harm the plastic. Its also great for removing sticker/double sided tape residue. Be careful with brake fluid or lighter fluid, it can make clear plastic turn hazy/cloudy. Last edited by Kylar; 11-15-2013 at 11:16 AM. |
06-10-2014, 10:14 AM | #7 |
Newbie Join Date: May 2014 Location: Auburn
Sorry to revive an old post, but I wanted to throw a couple pennies on the table for anyone looking in the future. DO NOT confuse Goo Gone with Goof Off. Goo Gone is citris based and shouldn't harm the plastic while Goof Off is chemical based and will fog your glass. CA Glue Accelerator spray will do the same thing... *sigh* I used rubbing alcohol and it came right off. I think Mineral Spirits would also work. |
how to remove new bright from windshield - Similar Threads | ||||
How to remove the new bright from new bright windsheilds's | tundrafan01 | General Scale Talk | 13 | 12-06-2010 01:30 PM |
