11-20-2013, 05:19 AM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: Hudson
| Fusion paint?
Would that Fusion paint work on Wraith body panels? The stuff is for plastic and is supposed to remain somewhat flexible. Thoughts? RIZ |
11-20-2013, 06:57 AM | #2 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
| Re: Fusion paint?
proper prep should allow any paint to stick to lexan. as with anything i would sand with a fine paper, clean, and spray. The fusion paint should not require a primer so one would think it could be used internally where a non lexan paint would have to have a primer and be sprayed externally.
11-20-2013, 07:12 AM | #3 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: Fusion paint?
Spray a test piece, see how it turns out. . |
11-20-2013, 07:30 AM | #4 |
Rock Stacker Join Date: May 2010 Location: Lotus, CA
| Re: Fusion paint?
I painted my PS body with Krylon Ultra Flat Camo w/Fusion. So far its holding up great. Only prep I did was to wipe the bpdy down with Denatured Alcohol however I don't recommend doing that with clear panels haha.
11-20-2013, 09:07 AM | #5 |
| Re: Fusion paint?
Did you paint to outside with ther fusion paint? Any pics? The reason I'm asking is I just got a Wraith in trade the the previous owner painted the panels yellow on the inside. I want to change the color and paint the outside instead. Just looking for any helpful tips to paint the outside of the panels. I happen to think of the Fusion paint this morning and decided to see if any others have used it. RIZ |
11-20-2013, 09:59 AM | #6 |
| Re: Fusion paint?
Yes I painted the outside. |
11-20-2013, 12:13 PM | #7 |
Rock Crawler Join Date: May 2013 Location: plains
| Re: Fusion paint?
I use the fusion paint on my lexan bodies and haven't had an issue with it.
11-20-2013, 07:57 PM | #8 |
Pebble Pounder Join Date: Mar 2011 Location: coastal georgia
| Re: Fusion paint? |
11-22-2013, 12:57 PM | #9 |
Quarry Creeper Join Date: Sep 2010 Location: In the pre-game lobby
| Re: Fusion paint?
I've been using fusion for a few years on my nb jk. Camo tan, same as the wraith above. Easy to use, & prep is hardly an issue. Tough as hell too!
11-22-2013, 04:20 PM | #10 |
| Re: Fusion paint?
Inside on lexan outside (obviously) on hard bodies. I e done outside on my ridgecrest body but scratched pretty easy. But that was used jus for a basher body so didn't really care much.
12-21-2013, 08:22 PM | #11 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
| Re: Fusion paint?
Did a lexan xj with true blue fusion painted on the inside body cracked from some unnecessary roughness but never had an issue with the paint |
01-29-2014, 08:33 AM | #12 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: Fusion paint?
I used fusion on a couple bodies, inside lexan, and they all sheeted off. I washed and scuffed them, but the paint just peeled off in sheets. Some people say they have had luck with it, but I know on lexan it did not work for me.
Fusion paint? - Similar Threads | ||||
krylon fusion paint......... | bob1961 | Paint and Body | 4 | 12-03-2011 07:53 PM |
Project: Fusion-X | Mikey007 | 2.2 Scale Rigs | 247 | 08-24-2010 06:46 AM |
Fusion packs | Flyin Hawaiian | Electronics | 2 | 05-13-2009 11:41 PM |
kryllon Fusion paint on lexan | Muddinguy | Paint and Body | 4 | 04-02-2006 01:08 AM |
