Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Tamiya clear coat
Old 08-17-2013, 01:33 AM   #1
Default Tamiya clear coat
Hi, just finished applying the 5th coat of gunmetal gray tamiya paint to my trailfinder, shes looking fantastic.
Just wondering if i should bother with the clear coat or not? If so, how many coats would be optimal?
Thanks.
e32lover is offline   Reply With Quote
Old 04-08-2014, 07:06 AM   #2
Default Re: Tamiya clear coat
I've read a bunch of guides/post online for my tf2 body - one of the better guides I've seen is - How to Apply, Polish, and Wax Your Paint to Perfection
After reading this, I decided against a clear coat since I'm not using metallic paint, and it makes any future mods/touchups difficult. Instead, i'm going to use polishing compound and wax after painting.
Here are some other posts that may be helpful -
D90 hardbody painting - need help! - RC Rock Crawlers & Scalers @ URC Forums
Hard body spray-ing
Painting Tamiya Hard Bodies - Scale 4x4 R/C Forums
http://www.j2drc.rchomepage.com/Scal...nt%20guide.pdf
littlebuddha is offline   Reply With Quote
Old 04-08-2014, 07:29 AM   #3
Fan of wheelspeed
Clear coat it with Testors Wet Clear. I would lightly wet sand the grey with a 2000 grit paper, then shoot it with the clear. Then wet sand again, followed by another coat of clear. After it has all cured then apply w silicone wax that dries clear (no white residue in the lines/cracks) the finish will be gut slick and easy to clean. Here's is a few examples of what the finished product will look like.
Hoosierdady is offline   Reply With Quote
Old 04-08-2014, 07:51 AM   #4
Another option for clear coating Tamiya TS paints.
This stuff is way more durable than Tamiya clear and if applied correctly wont need wet sanding or polishing as it is a high gloss clear.
Can be difficult to find in Australia but if you search around,you should be able to track some down.
Lead City Crawler is offline   Reply With Quote
Tamiya clear coat - Similar Threads
Clear Coat Over Decals? CountryChevy15 Paint and Body 2 02-24-2011 06:49 AM
enamal or laquer clear coat NeXt559 Paint and Body 1 11-11-2009 03:16 PM
Base coat/clear coat? jmbones Paint and Body 3 09-16-2007 12:30 AM
clear coat question RickSDMF Paint and Body 2 08-02-2007 06:20 PM
Lexan Clear coat? run2jeepn Paint and Body 16 12-31-2006 06:30 PM
