05-01-2014, 09:02 PM | #1 |
Quarry Creeper Join Date: Feb 2008 Location: New Rochelle
| Attach light buckets to bull bar
Does any one know of a good way to attach axial light buckets to a bull bar. Attached its two options of how I am thinking about putting my lights. I think I would like to attached them to the bull bar over the front bumper. Thanks |
05-01-2014, 09:33 PM | #2 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
| Re: Attach light buckets to bull bar
This is a quick cheap and easy way to mount them on tube work. The mounts have flat sides on them that lets them grip the tube pretty well. I just slide it over the tube while building it, but if the tube work is already done then cut it with an x-acto knife and add a bit of ca glue once in position to seal the cut and it will also help secure it, then use a 15mm length set screw to mount it and the light to it. When you run the set screw into the mount it will go all the way through it and set against the tube work to lock the mount in place then just spin the light bucket onto it. Mount pieces --- axial kits include a ton of these as spares. Slide onto bar and use M3 15mm set screw to mount, I only have 20mm right now so its a bit long but u get the point. Then twist light into it --Dan Last edited by sickcivic95; 05-01-2014 at 09:36 PM. |
Attach light buckets to bull bar - Similar Threads | ||||
how to attach my light bar | kgb424 | General Scale Talk | 3 | 07-15-2013 08:38 PM |
Dingo light bar or buckets | 65BAJA | Axial SCX-10 | 5 | 05-22-2013 02:37 PM |
Light kit t attach LEDs to lexan buckets | mszymanski25 | Electronics | 7 | 05-15-2013 02:06 PM |
