03-15-2015, 05:26 AM | #1 |
Newbie Join Date: Apr 2013 Location: Bethel Springs
| quick question
Ok I have searched n searched n searched. Look in the sticky and read the entire page on painting a body. I am not the best in the world but I do have a question. The cracks in a real vehicle around the doors, hood, tailgate, etc. Do you just paint a thin line for that? If so do you use flat, gloss, or semi gloss? I have seen pics of some that had the lines painted on them and was just wondering the easiest way to do that.
03-15-2015, 08:48 AM | #2 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: quick question
A thin black sharpy after paint is complete will create the shadows of the body lines you are looking for. If it is a hardbody, make sure you are completely done... I have made the mistake of sharpy before clear coat and the clear reacted with the sharpy to create bleading of the sharpy. Depending one the look you are after, a blackwash will also accentuate those body lines on a hard body. lexan.... just use the sharpy on the outside. Last edited by hotwheels000; 03-15-2015 at 08:50 AM. |
03-15-2015, 05:53 PM | #3 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
| Re: quick question
For lexan bodies, I use an Ultra-fine Sharpie. A small tissue with rubbing alcohol will make quick work of cleaning up any slips or do-over's, and won't harm the finish. For hard bodies, I use water based artist acrylic. A paper towel dipped in water, will clean up the excess, but do it before it dries. Works great and looks really good and can be mixed to make it different colors. When it dries, it's rubbery plastic that is water proof. Just make sure to do it after the clear is applied, also works best on gloss...flat might not allow it to come off completely for oops unless it is done immediately. Hope that helps. |
03-15-2015, 11:20 PM | #4 |
| Re: quick question
Thanks a lot for the replies!!! The body I am wanting to make look nice is lexan. I couldn't figure out the proper way to do that. The body I am painting is lexan and I will get a ultra fine sharpie and do it on the outside. I couldn't find if you was supposed to paint them on the inside or not. I ordered two bodies so I got at least on do over. LOL
quick question - Similar Threads | ||||
quick question | irollgen4s | Axial Wraith | 30 | 06-02-2012 05:19 AM |
quick question | sam.oc235 | Axial SCX-10 | 2 | 01-29-2011 06:47 PM |
California Gun owners. Quick question, need a quick answer. | Szczerba | Chit Chat | 8 | 11-23-2010 12:35 AM |
Quick Question | MoparMuddin | Axial AX-10 Scorpion | 7 | 04-30-2009 08:53 AM |
Quick Question... asking for quick answer.. | JeeperoManiako | Electronics | 0 | 10-13-2006 06:47 PM |
