Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Best method for removing old paint from hard body?
Old 07-19-2016, 10:01 PM   #1
Default Best method for removing old paint from hard body?
What's the best method for removing spray paint? Just pour some thinner on, let it sit for a bit then scrape off and respray?
kikcaffine is offline   Reply With Quote
Old 07-19-2016, 10:31 PM   #2
Default Re: Best method for removing old paint from hard body?
Paint remover, check if it is safe on plastic first.
Or just sand it and respray.
AngelowDoom is offline   Reply With Quote
Old 07-19-2016, 11:22 PM   #3
Zukiiholic's Avatar
Brake fluid
super clean degreaser
Dawn Power Dissolver
Zukiiholic is offline   Reply With Quote
Old 07-20-2016, 05:51 AM   #4
Brake Fluid works wonders for removing paint from plastic. But like said above, I'd just tape off the windows and paint it on the outside with polycarbonate paint. It will give it a satin finish and be fairly durable still. I've done this a bunch of times and it works well. Any other paint will scratch off super easy, but the polycarbonate paint actually sticks pretty well on the outside.
HDMM is offline   Reply With Quote
Old 07-20-2016, 06:37 AM   #5
Sand blasting. Lol
Sent from my XT1585 using Tapatalk
Waitwhatsthat? is offline   Reply With Quote
Old 07-20-2016, 07:33 AM   #6
He is looking for something to do a hardbody not Lexan If you have the time sand it with fine sandpaper, that will remove most of the paint and smooth out any gashes and dings in the plastic. After that shoot it with Primer then your final color coat.
Big Bill is offline   Reply With Quote
Old 07-20-2016, 10:06 AM   #7
yeah trying to find the best method that wont melt the hard plastic d90 body.
Old 07-23-2016, 05:30 AM   #8
Got some glow fuel? it works good for stripping styrene without melting it.
Originally Posted by Waitwhatsthat? View Post
Sand blasting. Lol
Black beauty @ 120 psi?
granite is offline   Reply With Quote
Old 07-23-2016, 01:37 PM   #9
IMO brake fluid. It's a nasty ass process no matter how you do it. Make sure you test it on a small piece first in case it melts the plastic.
Highmark is offline   Reply With Quote
Old 07-24-2016, 12:49 AM   #10
I used Brake Fluid on my Toyota Mojave body
It removed a couple layers of paint
But it made the plastic brittle and dull and kinda of pitted it
But it turned out ok cause I wanted it to have the well used look
I added the dents and the rust colored paint in the dents
kgb424 is offline   Reply With Quote
Old 07-25-2016, 10:59 AM   #11
I've used this before with very good success... provided you're patient.
Testors
It won't harm the plastic either. Can't say I've used it on a hardbody, but it removed old paint from a vintage slot car (soft plastic) and left the substrate clean and undamaged.
JohnB is offline   Reply With Quote
Old 07-27-2016, 01:52 PM   #12
sand blasting, media blasting, or thinner. but thinner is a mess. find a sandblaster!!!!!
CM9000 is offline   Reply With Quote
Old 07-27-2016, 03:53 PM   #13
I paint styrene and lexan.
DOT3 brake fluid will work well, BUT dont leave Lexan in too long.
91% (NOT 70%) rubbing alcholol , works well on most lacquers an enamels
80/20 Acetone / Water mix.....this is the fastest of all that I have used, WILL not dissolve styrene at this % dilute
mikemcE is offline   Reply With Quote
Best method for removing old paint from hard body? - Similar Threads
Removing paint from a hard body PIMPNROCKS Paint and Body 12 05-13-2014 11:42 AM
Removing Paint from a hard body tip! VanceH Paint and Body 3 03-14-2012 06:24 PM
Best method for removing paint from hard body? birdie Paint and Body 7 09-11-2010 12:50 PM
removing paint from hard body chino63 Paint and Body 11 12-09-2007 10:05 AM
removing paint from hard body chino63 General Scale Talk 7 02-03-2007 07:19 PM
