Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Panel painting
Old 03-26-2017, 10:22 PM   #1
Default Panel painting
Primer is on but not sure what kind of painting to us, can anybody help!?!
FordLighting is offline   Reply With Quote
Old 03-27-2017, 05:54 PM   #2
Default Re: Panel painting
What kind of material is it?
I guess it doesn't matter unless it's Lexan. Lightly sand or scuff the material, prime, and paint with whatever color or design you're going to put on. Just remember that the finish color and primer have to be both the same type of paint, i.e. enamel, lacquer, acrylic. You can't put an enamel finish over a lacquer primer and vice versa because the chemical structure of one paint will re-activate the other and bubble the finish.
Mike Flea is offline   Reply With Quote
Old 03-28-2017, 02:55 PM   #3
Thanks for the info on the chemical structure on the paint, I had no idea and would have probably used the wrong kind. But I did scuff the metal before I put the primer on. And as posting that question twice, it was by accident. I'm new to this site...... thanks again!
Panel painting - Similar Threads
switch panel ? middlemanw Axial XR10 2 04-25-2013 04:07 AM
Painting Basics - Painting Tips and Tricks stampedeproject Paint and Body 0 03-09-2008 10:39 PM
Can Panel Help Trimmy Paint and Body 3 01-20-2008 06:25 PM
Panel Materials RCHunter General Crawlers 8 05-07-2005 03:58 PM
