01-22-2018, 06:35 AM | #1 |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
| What do you use for window mask?
When you don't have the original window mask cut outs, what material do you guys find seals the edges and does a good job masking off windows?
01-22-2018, 07:08 AM | #2 |
Quarry Creeper Join Date: Aug 2017 Location: Satan's Armpit
| Re: What do you use for window mask?
I've used blue painter's tape for masking windows and painting two-tone and stripes on my rigs. You can get different widths, and score it with an Xacto knife to get clean edges.
01-22-2018, 07:44 AM | #3 |
Blue or green painter's tape (make sure it's high quality like 3M) or Bob Dively's liquid masking.
01-22-2018, 10:10 AM | #4 |
I use blue, and cut with a #11 to get the shape I want.
01-22-2018, 10:39 AM | #5 |
Are you guys doing anything special with this 3m blue painters tape before applying? I used it once before and got all sorts of color bleed and I tried the fingernail around the edges thing. Maybe I'm mentally deficient I don't know.
01-22-2018, 11:41 AM | #6 |
Retired clean room tape is the good stuff if you know anybody that works at a facility that uses it. If it ever gets accidentally brought out of the clean room, or the sealed packaging gets damaged, it can't go back in, so it gets tossed. Seals tight, removes clean. It's like $200 a roll if you had to buy it.
01-22-2018, 11:52 AM | #7 | |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: What do you use for window mask? Quote:
We used to "borrow" rolls from the production area to use in the labs and offices Sent from my Nexus 6 using Tapatalk | |
01-22-2018, 11:55 AM | #8 |
| Re: What do you use for window mask? Clean the body with alcohol so the tape sticks well. Then overlap it a good bit and ensure the edges are pushed down hard.
What do you use for window mask? - Similar Threads | ||||
window mask | dkchance74 | Paint and Body | 2 | 02-03-2015 10:11 PM |
Window Mask help. | eemmaaxxxx | Paint and Body | 5 | 08-04-2011 12:19 AM |
how to fix black "trim paint" bleeding under window mask via bubble? | username | Paint and Body | 6 | 03-15-2009 08:10 AM |
window mask?? | mudhunter | Paint and Body | 8 | 02-17-2007 12:59 PM |
