Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: What paint for interior
Old 08-08-2018, 03:14 PM   #1
Default What paint for interior
I'm looking at painting a DinkyRC interior that I have. Wondering what kind of paint to use for it. Not sure if I should be using lexan paint or plastic paint since I think it's styrene but not sure.
Asuckaphish is offline   Reply With Quote
Old 08-08-2018, 05:00 PM   #2
Default Re: What paint for interior
I would use the paints meant for Polystyrene, Tamiya calls them PS or just regular hardware store paint. Lexan is really the only material that requires a specific paint.
EDIT:dang it I got that backwards as Mike Flea mentioned you'd be after the Tamiya TS paints, sorry I wasn't thinking
HumboldtEF is offline   Reply With Quote
Old 08-08-2018, 05:23 PM   #3
I agree with Humboldt. The PS paints won't cause nasty side effects with the PS interior. Plus, they tend to be able to flex a bit like paints for lexan.
mewalsh100 is offline   Reply With Quote
Old 08-09-2018, 08:15 AM   #4
Thanks guys appreciate the help. Seems that my options are alot broader with the interior as opposed to the lexan body. I think I might want to hand brush the interior since masking the tiny curves and seams on the seats might be difficult to get a tight seal on.
Old 08-09-2018, 04:22 PM   #5
When I painted mine I used the cheap spray paint from Walmart. It came out great. I have better luck with the cheap paint than the expensive stuff listed as "for plastic."
struhall is offline   Reply With Quote
Old 08-09-2018, 04:46 PM   #6
Yeah I agree, I've had very poor results with "plastic paints" from the hardware store.
Old 08-09-2018, 06:02 PM   #7
Tamiya PS paints are for lexan, TS for styrene. My advice is test the PS on the styrene if you've purchased already, TS flakes on lexan, doesn't flex with the plastic, I learned the hard way.
Mike Flea is offline   Reply With Quote
Old 08-10-2018, 09:36 PM   #8
I've accidentally used tamiya ps paint on styrene and it melted it. Big mistake. I would stick with tamiya ts paint.
venomous98 is offline   Reply With Quote
Old 08-11-2018, 08:53 AM   #9
Taking notes here for my sons blazer body...
Wouldnt brushing the whole thing leave brush lines? I mean, unless you do super light coats and you are super patient. I think spraying would be better. Then go in with a brush for fine details. Am I wrong?
Shinchu is offline   Reply With Quote
Old 08-11-2018, 10:11 AM   #10
Awe shoot I got that backwards sorry, you'd want TS not PS (or you can use hardware store paint)
Old 08-11-2018, 10:21 AM   #11
Do you have a tabletop games shop nearby? Citadel paints are my favorite for painting interiors and details.
Water-based for easy cleanup and no smell, short drying times and many available colors and effects.
Don't bother with their expensive other tools.
zanthrax is offline   Reply With Quote
Old 09-01-2018, 04:36 AM   #12
Zanthrax, what do you use to protect the paint afterwards?
golfmech is offline   Reply With Quote
What paint for interior - Similar Threads
Tan and black interior paint for styrene rag6 Paint and Body 4 03-13-2017 06:55 AM
How to paint jeep interior Bitties5Deuce Paint and Body 10 03-24-2014 10:25 PM
Need some interior paint pointers. camobob Paint and Body 0 02-24-2011 03:40 PM
how did u paint ur cgr interior ebomb Paint and Body 1 04-06-2010 01:40 PM
