Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: VS4-10 inner fender?
Old 03-25-2019, 11:17 PM   #1
Default VS4-10 inner fender?
I was thinking about using Plasti-Dip on the inner fenders but on the tire side.
Have any of you done that and does it last at all? I know it’s cheap and I can repaint anytime I do damage. Just thought it would look more realistic with the matte black in there.
As a scale question has anyone 3D printed some? I have a printer and that would be even better for me.
CRAZYACE63 is offline   Reply With Quote
Old 03-26-2019, 06:21 AM   #2
Go Buckeyes!
B-MOW71's Avatar
Default Re: VS4-10 inner fender?
I did not use the Plati-Dip, but I did paint both sides with Tamiya PS-5 Black. I then sprayed both sides with Tamiya PS-55 Flat Clear. It gives it the flat black look. And it has held up great so far.
B-MOW71 is offline   Reply With Quote
Old 03-26-2019, 01:49 PM   #3
Cool. I think I will try the PD and if that just doesn't hold up I will give your paint tip a try.
Thanks
Old 04-11-2019, 02:25 PM   #4
PLastidip works great. I put 5 solid coats down on them and they havent come close to peeling. Just use a washer when bolting them down on the sliders and chassis
Joshs4x4toyz is offline   Reply With Quote
Old 04-12-2019, 03:20 AM   #5
Cool. I'll have to do that on the second set. I just did them in regular paint. I do need to trim them a bit so the body paint doesn't wear off.
VS4-10 inner fender? - Similar Threads
Other bodies on the VS4-10 mond Vanquish Products VS4-10 Origin 2 05-05-2021 01:15 PM
VS4 for the 1.9 noob mikemcE Vanquish Products VS4-10 Origin 137 04-09-2020 10:01 PM
akumu: vs4-10 v33 Vanquish Products VS4-10 Origin 37 01-07-2020 08:42 AM
Crawler505’s VS4-10 Crawler505 Vanquish Products VS4-10 Origin 19 10-13-2018 08:31 AM
