Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Multi colour hardbody paint job help
Old 11-10-2019, 08:13 PM   #1
Default Multi colour hardbody paint job help
I'm about to attempt a similar paint job on my D90 to the 1:1 in the photos.
Going to swap the blue for black though. I would also like the block colours to fade into the white where joins if possible.
I would love some input on the right method to nail it.
My thoughts are this order:
1. Prep and prime.
2. Spray front half black and back half orange.
3. Mask up the orange and black jagged design.
4. Spray whole body in white. Paying attention to feathering in the white where it joins the other colours with a shield or a mesh.
5. Wet sand
6. Apply decals
7. Clear coat.
Any advice or help is appreciated, never done anything like this before!
Sent from my LYA-L09 using Tapatalk
nedmo is offline   Reply With Quote
Old 11-11-2019, 04:40 AM   #2
Default Re: Multi colour hardbody paint job help
For exterior paint, go light to dark, for inside lexan, dark first. SOP!
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 11-11-2019, 01:02 PM   #3
Hang up and Drive
Okay cool...so reverse order. It would make it easier to do a fade in then. I would draw two lines in the jagged mask...one for the hard change then a second one further in to mist a fade with the block colours.
1. Totally coat in white.
2. Cut out Mask for orange section and paint orange.
3. Cover orange section and cut out Mask for black section.
Old 11-11-2019, 03:21 PM   #4
Yessir, key is to make sure paint is hard enough so the tape doesn’t lift it. I also like to use a clearcoat between paint and edge of tape to prevent bleed , lay tape and burnish to seat edge, then clear that edge, wait and then color. Rare to get any bleeding that way, HOK makes an undercoat clear (SG100) for this between graphics .
Hang up and Drive
Old 11-11-2019, 04:01 PM   #5
Yep I'm super concerned with masking on-top of paint. Will let the initial white layer dry for at least a week before progressing.
Old 11-11-2019, 04:34 PM   #6
Overkill, Overnight is way too much. Most paints have a recoat window, Tamiya TS is 72 hours if not done in the first 4.
TS lacquers flash and dry quickly. 3 coats, wait 3 hours then tape. Use the good tape, not the green stuff
Hang up and Drive
Old 11-11-2019, 04:59 PM   #7
Hang up and Drive
Thank you sir! I was actually just going to use hardware paint, like this https://www.bunnings.com.au/rust-ole...range_p1580692
Is it worth using TS?
Old 11-12-2019, 04:44 AM   #8
If you want a crisp sharp paint job, quality paint is needed. Trouble with some solvent paints is incompatibility causing bubbles and other awful things.
Hang up and Drive
Old 12-03-2019, 06:05 AM   #9
Good tips ^^ Myself use a smell test to check if paint has cured. Paint gasses out as it cures, dry paint has no paint smell .......
@ mikecE .... Everglades did a bunch of camping there when living in Miami
Small world
Pep
JacktheRipper is offline   Reply With Quote
Old 01-02-2020, 01:00 AM   #10
Got the colour done. Few mistakes...mainly from using old masking tape on the blue section! But overall pretty happy.
Old 01-08-2020, 06:48 PM   #11
Came out good. nice
pep
Multi colour hardbody paint job help - Similar Threads
1973 Ford Bronco and 1966 Chevrolet C-10 Clear Body paint colour prontozuk Paint and Body 10 01-30-2019 04:32 PM
How do I paint my car to get this red colour? robo555 Paint and Body 3 07-10-2014 04:14 AM
What colour to paint my Honcho?!? fbuonpensiero Axial SCX-10 13 04-02-2011 02:52 PM
Green paint colour on the betty body Paul1234 Axial AX-10 Scorpion 1 06-05-2010 03:20 PM
Paint job D-Wreck Chit Chat 11 07-29-2006 06:57 PM
HTML code is Off
