Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: De-bonding hard body cab back...help?
Old 10-21-2020, 04:12 PM   #1
Default De-bonding hard body cab back...help?
Lol so as the title says I need to remove this cab back from my Hilux... it’s from Loops Models and made of “hard black plastic similar to abs.”
I used the 3 “glue” method
1. Bondene
2. CA - BSI Medium
3. Shoe Goo
I didn’t finish it yet so I can still get into most of the gaps if that makes a difference? BSI makes an “un-cure” but it will probably deform the body I’m thinking...
Here are some pics:
Hoping one of you tinytruck wizards has a solution???
VR6 BeelzeDub is offline   Reply With Quote
Old 10-21-2020, 04:18 PM   #2
Bondene melts the plastic
CA fills a gap and dries hard.
Shoe Goo dries flexible covering gaps .
My Advice is a sharp blade or diamond wheel.
Once melted you have to separate solid plastic. So seams and gaps don’t matter anymore.
As an old wizard taught me, it’s plastic, add some , sand it smooth
Hang up and Drive
mikemcE is online now   Reply With Quote
Old 10-22-2020, 09:35 AM   #3
Default Re: De-bonding hard body cab back...help?
Yeah, I'd also recommend a mechanical removal (as opposed to chemical).
Sharp razor blade, diamond dremel wheel, maybe even try the sharp corner on the backside of an olfa type box cutter blade.
QuesoDelDiablo is offline   Reply With Quote
Old 10-22-2020, 04:57 PM   #4
I was worried you guys were gonna say that... lol
The cab back has a lip designed to sit inside the roof/pillar section of the body and the window detail sits flush with the outside (forming a corner joint).
I’m thinking I’ll have to cut along the window and through the piece, leaving the backing lip attached to the inside of the body...
Appreciate the responses
Old 10-22-2020, 05:28 PM   #5
Straight cuts are easier to finish. I would square cut it and to reassemble but join it with CA and micro balloons or talcum powder. Then finish it wit 2part glazing putty, sand smooth, paint. Don’t forget it’s just plastic, easily repaired.
Hang up and Drive
Old 10-22-2020, 09:05 PM   #6
Talcum powder and CA for butt joints...that’s interesting. I’m gonna look that up.
I’ve settled on having to make a straight or square cut now simply following the body line. That’s easy enough. And I’m not concerned with saving the cab back. I’ll just need to remove the bit that’s left over bonded to the inside of the cab to use another cab back that allows the bed to be attached.
De-bonding hard body cab back...help? - Similar Threads
Injora Cherokee Cab/Back half cage hard body truggy DeoreDX Paint and Body 18 06-14-2022 07:22 PM
Best way to remove the half cab back to install full cab back bent_hinge_pin RC4WD Trail Finder 2 11 07-07-2018 11:36 PM
