11-21-2021, 11:39 PM | #1 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| What type of paint should i use?
What type of paint should i use to paint the driver,i need to see him good, not all in black? Since its lexan, should i use lexan paint,or just some type of paint markers? Also what kind of paint markers y'all suggest? Sharpies perhaps? Thanks again guys! Sent from my LGMP450 using Tapatalk |
11-22-2021, 05:41 AM | #2 |
Quarry Creeper Join Date: Nov 2020 Location: Greece
| Re: What type of paint should i use?
Since it's lexan, I'd say go with the PS paint, but it will require a lot of masking to get the details. Maybe if you sand him lightly, you could apply normal paint with a small brush? If it won't get scratched it should last OK
11-22-2021, 07:35 AM | #3 |
Sharpies work well on lexan, but rub off after awhile.Lexan paint is the best bet. You can lay down a coat of lexan pain then put down normal paints over it. I hear acrylic paints work, but I have 0 experience with them
11-22-2021, 09:06 AM | #4 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
From my experience you can easily get away with brushing any paint on the interior panels as they aren’t subject to the impact stress of a lexan shell. Personally I would just put a coat of clear ps paint on first and let it cure. This will help with adherence of the brushed paint and any minor flexibility issues you might encounter.
11-22-2021, 09:09 AM | #5 |
Rock Crawler Join Date: Apr 2020 Location: Drums
This area is protected from scratches so I'd just brush paint from the outside with Testors. May help to spray with primer first so you don't need as much paint to get good coverage if you're going to lighten it up. That's how I did the interior of my Scorpion, only I wasn't smart enough to primer it first. When done, I sprayed it all with flat clear to get rid of the gloss. You can see a photo toward the end of this thread: Quick Lexan body prep question Last edited by OnTheTrail; 11-22-2021 at 09:23 AM. |
What type of paint should i use? - Similar Threads | ||||
Paint type? | TIREBUSTER | Paint and Body | 10 | 01-23-2018 07:41 AM |
What type of paint | charvel74 | Paint and Body | 4 | 01-31-2017 07:50 PM |
What type of paint to use | Wehlee | Paint and Body | 1 | 04-09-2016 12:59 PM |
What type of Paint to paint outside and plastics | photocycler | Paint and Body | 1 | 10-24-2014 12:54 AM |
