10-12-2022, 08:25 AM | #1 |
Rock Stacker Join Date: Feb 2018 Location: Pan Handle
| Fiberglass to polycarbonate
Anyone ever try using Bondo type fiberglass resin repair kit to re enforce a polycarbonate body? Will it stick or will it eat into the body? https://www.walmart.com/ip/Bondo-Fib...7?athbdg=L1200 |
10-12-2022, 08:55 AM | #2 |
Quarry Creeper Join Date: Mar 2021 Location: SOCAL
| Re: Fiberglass to polycarbonate
my guess is that it might chip out depending on the use ... if its a slow crawler it be fine but if you are planning to use the body to bash around it will likely not survive. The lexan gives a little flex, the cured putty might be very rigid as compare to the lexan. also weight !!! I prefer to use the drywall tape and shoegoo method for reinforcement, I do this to the bash bodies for the go fast cars but for the crawlers i just back the paint with truck bed coating spray ... helps to thicken the body and giver depth to the paint without taking the flex out of it. So far all the crawler bodies nave no tears or cracks.
10-12-2022, 09:35 AM | #3 |
I've seen bodies warp from the heat some " reinforcements" put out. I've always used drywall tape and shoogoo.
10-25-2022, 12:54 AM | #4 |
Newbie Join Date: Oct 2022 Location: The KBC Void
You know, I had a whole answer written thinking you meant Bondo body filler, then I actually followed the link and saw the fiberglass cloth. Yes, you can do it - Epoxy doesn't attack polycarbonate, and if you do it correctly, the fiberglass will stick and not flake off at all. 1-2 layers of fiberglass has more than enough flex to not be a problem. Just don't be surprised when you screw it up. Fiberglassing is a skill - you can learn it, but expect a learning experience and disappointment at first. Even Jimi Hendrix had to learn to play guitar. Personally, I wonder what Gorilla Glue (which turns into a dense rubbery foam) and plain 'ol cotton or nylon would do. I'll certainly get a chance to try... (The Walmart Fiberglass is a bit heavy for my liking, and the resin is probably less flexible than I'd like...) |
11-04-2022, 09:28 AM | #5 |
I prefer using LiquiSole and cheap (slightly) adhesive fiberglass tape instead of resin and fiberglass cloth. Sticks well to the lexan body and is very elastic so it doesn't flake. |
11-04-2022, 10:56 AM | #6 |
Rock Crawler Join Date: Apr 2017 Location: Northeast PA
| Re: Fiberglass to polycarbonate Shoe Goo is really hard to beat. The adherence to polycarbonate is amazing and it's super tough. I've also experimented with E6000, which is similar to Shoe Goo but not exactly the same. E6000 has better self-leveling properties, dries clearer and stays more flexible when compared to Shoe Goo. But it doesn't adhere quite as well to polycarbonate. |
11-05-2022, 11:49 PM | #7 |
Rock Stacker Join Date: Sep 2022 Location: Central CT
I have used shoe glue with carbon fiber cloth inside of a clear body. On my bashers. You get the carbon fiber body but it’s flexible like the drywall tape trick still. I would imagine fiberglass would be easier to work with, as carbon fiber fabric tends to fall apart really easily Sent from my iPhone using Tapatalk |
11-07-2022, 02:23 PM | #8 | |
| Re: Fiberglass to polycarbonate Quote:
I wonder what a layup of Kevlar or Nomex under Polycarbonate would work for longevity. Aramid fibers are much better than even carbon fiber for impact, abrasion, and fatigue resistance. They also don't block radio frequencies the way Carbon Fiber does. The yellow color isn't the prettiest, though. | |
11-07-2022, 03:53 PM | #9 | |
11-07-2022, 04:58 PM | #10 |
| Re: Fiberglass to polycarbonate Yeah, I'm looking at getting a vacuum system myself (for composite layups - 'glass, CF, Amarids). I do high power rocketry as well, and getting out bubbles, and sucking out every gram of unnecessary resin is critical for strength and weight.
11-07-2022, 05:41 PM | #11 |
I'll just add you dont want epoxy as it dries hard, what you want in the end result is flexibility. E6000 or shoe goo is the way to go.
Fiberglass to polycarbonate - Similar Threads | ||||
Polycarbonate paint | Green River | Paint and Body | 35 | 01-23-2022 09:18 AM |
Painting polycarbonate with line-x on the outside | crawlerjunkie | Paint and Body | 6 | 04-08-2020 03:01 PM |
1/6 polycarbonate MT build | F.i.M.S presents Rc. | Mega/Monster Trucks | 15 | 08-29-2018 04:47 PM |
Need Help Bonding Polycarbonate | Casper06 | Paint and Body | 3 | 03-09-2009 06:56 PM |
