02-04-2014, 01:18 PM | #1 |
Newbie Join Date: Jan 2014 Location: Redondo Beach
| Tamiya Datsun 240Z body on XV-01 Pro Chassis?
Hey Rally guys, This will be my first rally car. I am in love with the Datsun 240Z that Tamiya offers and was about to pull the trigger on the DF-03Ra kit. (I have already ruled out the old TT-01E kit) Someone mentioned the XV-01 pro chassis and how much better it was than the DF-03Ra. So my question is, will the Datsun 240Z body fit directly on the XV-01 chassis with little to no modification? I'm sure someone has done it but a quick search didn't turn up any results. TIA |
02-04-2014, 09:01 PM | #2 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
| Re: Tamiya Datsun 240Z body on XV-01 Pro Chassis?
It hasn't been done, because sadly the wheel base is different. It only works with the DF03Ra because the wheelbase is adjustable. But the XV-01 platform is so good I just don't see any reason to buy anything else. It might be possible to make it fit the XV-01 platform, but I don't think anyone has explored it in depth.
02-05-2014, 08:20 AM | #3 |
Newbie Join Date: Apr 2013 Location: Philippines
If you have decided to give up on the XV01 chassis, you can still have a newer rally spec chassis that can fit the Datsun. Check out the TT02, you easily can set it up for rally out of the box. Or, you can just cut the wheel arches of the body differently. The wheelbase for the Datsun is just 5mm shorter than the standard ones. Last edited by Smile; 02-05-2014 at 08:25 AM. |
02-05-2014, 09:14 AM | #4 |
Pebble Pounder Join Date: May 2012 Location: STRONGSVILLE
I'm sure you can massage it on there. 5mm isn't that much really. You can cu out the fenders more and then add flares to cover it up some
02-06-2014, 08:14 AM | #5 |
Yeah.. was hoping someone might have already done it and save me the R&D. haha I might just go with the DF-03Ra kit. It will be run on a limited basis and the need for the BEST chassis is not that great. |
02-06-2014, 08:47 AM | #6 |
As long as your batteries are small enough and you don't mind dealing with ball diffs then the df03ra isn't a bad chassis especially considering that your electronics are small enough to fit as well
02-06-2014, 10:16 AM | #7 |
It is pretty noticeable. I dropped that body on my DF03 before changing the WB and it didn't look right at all. Pretty sure the XV does not go down to that WB (at least, not with the dirt shields installed) though I'm not 100% sure. The older TT01's could do it though. I believe that body was even offered on a TT chassis if I remember correctly. |
04-29-2014, 05:06 AM | #8 |
Newbie Join Date: Jun 2011 Location: London
Does anybody know if the Castrol Celica '93 or '97 can fit on the XV-01 or do those bodies also have the same slightly shorter wheelbase than the XV-01?
04-29-2014, 03:20 PM | #9 |
Rock Stacker Join Date: Apr 2014 Location: Las Vegas
05-06-2014, 11:04 AM | #10 |
| Re: Tamiya Datsun 240Z body on XV-01 Pro Chassis? |
02-05-2015, 10:00 PM | #11 |
Which year body did you find?
02-14-2015, 12:51 AM | #12 |
Newbie Join Date: Sep 2014 Location: tacoma
Love the 240 body man..plan on getting one for my other rally/drift car to go next to my general Lee... |
02-25-2015, 03:07 PM | #13 |
Rock Crawler Join Date: Sep 2008 Location: Kennesaw
i have the tamiya 240z body on my xv01..........
Tamiya Datsun 240Z body on XV-01 Pro Chassis? - Similar Threads | ||||
Datsun 240Z Fairlady DF03ra | Grumpster1980 | Non Crawler RC's | 12 | 02-22-2011 10:55 AM |
looking for a datsun pu body | lonwlf | Newbie General | 24 | 10-20-2006 07:41 PM |
