05-12-2014, 12:34 PM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: DENVER
| WAFFLE's xv-01
Scored a Xv for a great price locally, was like new for $150 with some cheap electronics rtr, LOL! Installed a MMP, tekin 13.5, Jr 9100s, a futaba Rx 3s 50c lipo and put a pretty good beating on it stock, only issue I had was the stock spur and pinion shredded, and I popped off a link and lost a dog bone. (on the right) After running it though its paces, I felt it needed better shocks, That was my main priority. Other than that It was a great and tough little car. I opted to just buy all the upgrades That I wanted for the car at once and do all the mods at the same time because this car is a pAin-in-tHe-aSs to work on to say the least. I hated the Phillips screws and the need to strip the car to get to everything. Current setup: Mamba max pro Tekin 13.5 (12°) sensored Jr 9100 speed 3s 50c 2200 Futaba 4pls 77/26 Tamiya rally blocks Tamiya 18 spoke wheels 54340 Gmades xd 45 weight 2 hole pistons Here's my list of upgrades: Yeah racing Ti Hex screws 2x Tamiya carbon rear damper stays 62mm Gmade xd shocks Front and rear Tamiya CVDs Front and rear Tamiya alum. pulleys Tamiya reinforced belt Yeah racing knuckles and rear hubs Tamiya anti sway bars/rod stoppers Tamiya slipper clutch Traxxas rod ends TRA1942 Tamiya carbon upgrades, battery tray/steering, suspension mounts, a-arms, spacers, rocker arms My pictures didn't come out to great but the carbon upgrades are Much stronger and the best part is, lighter. Carbon 29.4g Stock 32.6g Carbon 7.8g Stock 8.7g Carbon 5.6g Stock 6.1g The steering bearings were shot, put in some Traxxas bearings. Weird slipper design Rear carbon damper stays front and rear with gmade XDs with a little bit of work. Cant fit the Gmades with the spur cover so that had to go. Had to use spacers to get the shocks positioned right to clear the knuckles and cvds, ect. The stock body fits with no issues, I obviously had to cut new holes with a rear damper stay in the front now and use a rear body post in the front as well. Current body with tarmac tires: Thunder tiger STi pre-painted Hpi Pirellis s and d compound Hpi wheels HPIC4286 on blocks: Last edited by WAFFLE; 05-12-2014 at 03:37 PM. |
05-12-2014, 08:42 PM | #2 |
Newbie Join Date: Oct 2013 Location: SoCal HB
| Re: WAFFLE's xv-01
Did the rear shock tower (dampener stay) bolt right up to the front? Also with those G-Made shock did you have to limit travel any for the front with your set-up......details please Thanks BulldogSRT |
05-12-2014, 10:20 PM | #3 |
Rock Crawler Join Date: Apr 2013 Location: Buena Vista
| Re: WAFFLE's xv-01
kick ass man! so now you have 2? Set one up for s2000?
05-13-2014, 11:52 AM | #4 | |
| Re: WAFFLE's xv-01 Quote:
Here some pictures of the spacers: No the light blue ones stroker's (ben's) he just had it up at the shop. Last edited by WAFFLE; 05-13-2014 at 09:22 PM. | |
05-13-2014, 12:29 PM | #5 |
| Re: WAFFLE's xv-01
ah I saw ben's car and figured you were ben...
05-13-2014, 06:56 PM | #6 |
Quarry Creeper Join Date: Jan 2013 Location: Long Island, NY
| Re: WAFFLE's xv-01
Do you have a link to those shocks?
05-13-2014, 09:19 PM | #7 |
| Re: WAFFLE's xv-01 |
05-16-2014, 06:02 PM | #8 |
05-19-2014, 09:53 AM | #9 |
| Re: WAFFLE's xv-01
Drove this car over the weekend, mostly tarmac, I'm loving the handling with the sway bars. The sway bars really allow you to fine tune your shocks(run them softer with no effects on handling) to suck up all the bumps. I was blown away by the cars handling stock, but with sway bars and good shocks its ridiculous. |
05-21-2014, 02:16 PM | #10 | |
05-21-2014, 08:51 PM | #11 |
| Re: WAFFLE's xv-01
They bolt on. On the front these shocks are a tight fit with the spur/pinion cover.
05-22-2014, 03:21 PM | #12 | ||
Everything's explained really well above too! Last edited by WAFFLE; 05-22-2014 at 03:24 PM. | ||
