06-03-2014, 08:31 PM | #1 |
Rock Stacker Join Date: Feb 2013 Location: Seattle
| Quick XV-01 Question!
I have 1 XV-01 Pro, and it drives like a champ. I also have a regular XV-01 with all kinds of hop ups, but for the life of me, I can't get it to go straight! I have a cheap Servo and Radio combo, could this be doing it? I looked at the steering, and everything looks fine, nothing bent. Has anyone else experienced this? I want to spend some money to fix this, just want to make sure I'm spending in the right direction. Thanks guys!
06-03-2014, 10:26 PM | #2 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
| Re: Quick XV-01 Question!
Servo or some kind of binding in the steering system.
06-03-2014, 10:35 PM | #3 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
If it's a cheap servo its prob not centering correctly. Hitec 645 is cheap but works great. I would start there
06-04-2014, 10:36 PM | #4 |
| Re: Quick XV-01 Question! Eh, thats a pretty slow servo. These cars don't really need much torque, maybe 100 ounces. More importantly is the transit speed, look for something .11 or faster.
06-27-2014, 04:50 PM | #5 |
Replaced the servo, had the same problem. Swapped in a new radio, had the same problem. Guess I will just rebuild the steering linkage.
06-28-2014, 12:10 AM | #6 |
What was in it before and what did you swap in? Did you check the steering linkage without a servo attached to see if it moved freely? What ESC are you running? Do you have a BEC? Im kinda thinking the tie rods that attach to the front knuckles are binding on the chassis. Mine did this as well, which caused the steering to pop and bind a little. If that is the case it is a very easy fix. |
07-01-2014, 06:21 PM | #7 | |
| Re: Quick XV-01 Question! Quote:
Quick XV-01 Question! - Similar Threads | ||||
quick question | 507Eli | Electronics | 2 | 01-03-2012 12:30 PM |
California Gun owners. Quick question, need a quick answer. | Szczerba | Chit Chat | 8 | 11-23-2010 12:35 AM |
quick question | newatthis | Tamiya Txt-1 and Juggernaut | 2 | 01-24-2010 08:34 PM |
Quick question | hummer6504x4 | Newbie General | 3 | 05-28-2008 05:57 PM |
Quick Question... asking for quick answer.. | JeeperoManiako | Electronics | 0 | 10-13-2006 06:47 PM |
