03-12-2016, 03:07 PM | #1 |
Rock Stacker Join Date: Dec 2015 Location: toronto
| best motor combo for xv-01 newby?
I have a xv-01(rally ready) with the stock motor, and I wanted to know if there was any brushless motor combo that had a wire that was long enough. also one very important thing: it needs to have everything soldered. I don't have a solder iron. so is there any? thank you |
03-12-2016, 03:44 PM | #2 |
Rock Stacker Join Date: Jul 2011 Location: Sandown
| Re: best motor combo for xv-01 newby?
You could always have your LHS solder up longer wires for you. The ones I've been to are usually fairly reasonable with work like that. Sent from my iPhone using Tapatalk |
03-12-2016, 10:33 PM | #3 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
There aren't any with long enough wires stock. You'll have to get a friend or a hobby shop to solder wires of a suitable length for you. Anyway, as far as the motor is concerned, something in the vicinity of 3000KV will give you a good amount of speed with a wide range of adjustment possible by changing the pinion gear. Remember it's technically an off-road car, so you don't want a super-high-speed motor or you'll overheat it running on anything except pavement. |
03-13-2016, 08:40 AM | #4 | |
| Re: best motor combo for xv-01 newby? Quote:
03-13-2016, 10:26 AM | #5 |
I use Team Orion Method Pro brushed motors for all my non-crawler brushed-motor needs. Something in the vicinity of 15 turns with a 25-30 tooth 48p pinion should work well. (if you're still running the stock spur gear, you'll have to get Robinson Racing Mod 0.6 gears instead of 48p -- the same gear range would be 22-27 teeth for that gear pitch.) I use Tacon motors for all my brushless motor needs. I had one vehicle that ran a Tacon sensored motor, but I sold that truck, and I haven't missed the supposed extra precision of running a sensored motor. All my other brushless motors are sensorless and they work just fine. Tacon is made by the same company as Leopard, though, and Leopard has a decent selection of sensored brushless motors if you really want one. Of course there are other brands, but Tacon/Leopard are inexpensive and durable enough for my needs. |
03-16-2016, 11:00 AM | #6 |
I ordered a speed passion revention combo. does anyone know about this combo? also thank you for all of you who answered |
03-16-2016, 10:03 PM | #7 |
No idea. What KV did you get?
03-17-2016, 05:31 PM | #8 |
| Re: best motor combo for xv-01 newby? |
03-19-2016, 01:54 PM | #9 |
Okay, you'll want about a 23t 48p pinion gear for that KV. Also, get the XV-01 slipper clutch kit if you don't have it yet, it lets you use 48p gears. (The original gears are Mod 0.6, which is an inconvenient size.)
03-22-2016, 07:07 PM | #10 | |
also, thank you! | |
04-05-2016, 07:10 AM | #11 |
Rock Stacker Join Date: Jan 2008 Location: Escondido
Which pinion gearing are you guys using for a 10.5 motor with the 77t spur gear 48 pitch that comes with the slipper clutch?
04-05-2016, 05:01 PM | #12 |
The motor mount allows a minimum tooth count of 100t, so you can run pinion gears from 23t - 38t. Larger than 38t will require cutting on the inside of the gear cover. You can also run an 81t spur gear from Associated (the slipper pads are the same size and shape), which will let you run pinion gears as low as 19t. My XV-01s are geared thus: Touring car w/ 4000KV (9t) brushless motor: 32/77 = 40mph Touring car w/ 12t brushed motor: 24/77 = 30mph Rally car w/ 12t brushed motor: 19/81 = 26mph Rally car w/ 27t brushed motor: 40/65 = 25mph Last edited by fyrstormer; 04-05-2016 at 05:04 PM. |
08-22-2016, 11:53 PM | #13 |
Newbie Join Date: Aug 2016 Location: san jose
If you want something stock that will drop right in and have long enough wires you could get castle sct set up. The wires are plenty long and it's what I run in my xv-01 pro.
11-13-2016, 05:17 PM | #14 |
I wanna be Dave Join Date: May 2010 Location: The east coast
Looking for some advice. Would a castle sidewinder sct esc with 4 pole 3800 brushless combo be a reasonable choice? I would be running on 2s. I have a tazer 12t esc and 15t brushed combo laying around but was thinking a brushless system would be a nice upgrade. |
11-13-2016, 07:18 PM | #15 |
It's fundamentally a touring car. It doesn't need 4-pole. However, if 4-pole is what you have, it will work fine. The KV is in the right range.
best motor combo for xv-01 newby? - Similar Threads | ||||
What motor combo? | kdub41 | Traxxas Crawlers | 11 | 07-30-2012 09:40 PM |
Motor combo | Figjamjake | Axial Wraith | 3 | 04-18-2012 04:43 AM |
Newby, and need a little help with WK motor? | hambyl88 | HPI Wheely King | 4 | 09-16-2010 02:59 PM |
motor combo | Robb8 | Team Losi Comp Crawler | 17 | 01-21-2010 09:35 PM |
