09-01-2009, 05:48 PM | #1 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
| Bastard jr. chassis and Bully's?
Anyone use the bully's with a Bastard jr. chassis before? Tried searching but came up snake eye's. I'm getting a second one and would like to do a Bully MOA with it. Pics or links if you've got'm. Thanks. Any issues you see with the set up as well would be appreciated.
09-01-2009, 06:04 PM | #2 |
Quarry Creeper Join Date: Jun 2009 Location: Winchester
I don't forsee any problems with that, try it, and if it doesn't work, make it work
09-01-2009, 06:05 PM | #3 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
Might be a cool looking build! The chassis is good and small.
09-01-2009, 06:06 PM | #4 |
Pebble Pounder Join Date: Apr 2008 Location: Hong Kong
not a bastard jr but i have bullys mounted on a DMG tuber. I would presume it would be similar with the wider skid and spaced out link location. I just used bent lower links and turned the bend outwards instead of upwards (not sure if this makes sense to you). Anyways, there's plenty of clearance bet links and motor with this setup. Hope this helps
09-01-2009, 06:26 PM | #5 | |
09-01-2009, 06:52 PM | #6 |
Newbie Join Date: Sep 2008 Location: Dallas, Texas
do it, I've been thinking about doing the same thing with some bullys and I would really like to see what it would looks like
09-01-2009, 06:55 PM | #7 |
Could use a little longer links up front to push the motor out in front of the chassis if needed. |
09-01-2009, 07:39 PM | #8 | |
DMG/Bully/Mayhem - Finally... | |
09-01-2009, 07:39 PM | #9 |
I'm probably going to try it (atleast see if they'll mock up.) I'm working on making a shorter length Bastard like a moon buggy comp rig and there's room to shorten the rear and lengthen the front to make'm fit if neccessary. Gonna do some more research.
