Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Y-Town Double Agent 2.0- Matt's
Old 01-09-2017, 11:24 AM   #41
Default Re: Y-Town Double Agent 2.0- Matt's
OUCH! Snaggletooth gears.
travis c. is offline   Reply With Quote
Old 01-09-2017, 12:18 PM   #42
Originally Posted by tapped-out View Post
That really sucks Matt. Hope You get bearings before our comp this Saturday.
BTW I have a set of berg axles FS..
I have the bearing. I'm waiting on the gears. The gears should be here Thursday.
If all else fails I can run the original rear axle in the front.
SDheavymetal is offline   Reply With Quote
Old 01-11-2017, 04:43 PM   #43
Originally Posted by Robbob View Post
One of the three reasons I havent switched over my front axle yet. Not that the xr is any better lol but I feel safer for now.
I have NOT been nice to the front axle at all. The XR10 would front gears would have been popping by now. These axles are very strong.
I do miss the XR steering!
Old 01-11-2017, 05:01 PM   #44
My Berg gears have been going strong for yrs
See you Sat morning Matt.
tapped-out is offline   Reply With Quote
Old 01-15-2017, 11:55 PM   #45
I just got some new side plates. I broke the other one. Jake now makes stronger side plates. I also received 4 new shock mounts.
The old one verse the new design.
Old 02-05-2017, 01:33 PM   #46
Shock rebuild time.
I got some new Pistons from Krazed Builds.
SCX Machined Piston Tuner Sets | Krazed Builds
And some new springs and spring seat from RcBros
Shocks
Well i drilled a hole in the caps so I can install blatters. This is how I install the o'rings. I like to put the rings on the shaft first then slide them into the body. I do that so hopefully don't damage the o'rings.
The shock leak less if I put the 2 o'rings then the spacer. Axial says to put the spacer between the 2 o'rings.
Old 02-15-2017, 03:20 PM   #47
The chassis stiffeners would move a little. So I made small notches in the nuts. It seems to be holding the stiffeners now. Here is picture of the notch in the nut. Then I turned it to line up with the plate.
I had the same issue with stiffeners moving
Here is another optional fix get some Duratrax 3mm serrated flange nuts PN# DTXQ 0413 .
Makes life a lot easier plus more surface area to hold the CF chassis braces no more movement now
Tom G is offline   Reply With Quote
Y-Town Double Agent 2.0- Matt's - Similar Threads
Farmertom's Y-Town Double Agent 2015 farmertom72 Axial XR10 17 03-22-2016 06:27 PM
Bc's Y-Town SA 4.0 to bodied Double Agent Bc Paints Axial XR10 79 11-03-2013 01:38 AM
Y-Town Double Agent on the Rocks racer_zh Videos! 7 07-10-2013 12:54 PM
