06-04-2016, 11:26 AM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Norway
| Bully 2 axle?
Is it more than one version of the bully 2 axle? Found some on ebay that has a axle width of 193mm. The axle housing look different to. Part number RWDZ-A0020. |
06-04-2016, 11:51 AM | #2 |
RCC Addict Join Date: Jul 2008 Location: San Diego
| Re: Bully 2 axle?
Yes there is more than one Bully axles. Part numbers and description for each. Front Bully2 Bully 2 Competition Crawler Front Axle Rear Bully2 Bully 2 Competition Crawler Rear Axle |
06-04-2016, 11:51 AM | #3 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: Bully 2 axle?
Yes v1 and v2 sets of bully axles I wouldn't use v1 axles. V2 bully axles would be the way to go if you wanted bully axles..Bully 2 Competition Crawler Front Axle If I was looking to buy a set on competition axles I'd personally pick up a set of D-lux Berg axles https://dluxfab.ecwid.com/#!/2-2-cla...tegory=6232189 you'll need to buy gears for D-lux axle v1 Berg gears |
06-04-2016, 12:04 PM | #4 |
RCC Addict Join Date: May 2011 Location: at home
| Re: Bully 2 axle?
z-a0012 and z-a0084 are the newer bully 2 competition crawler axles front and back with lengths of 219.5mm hex to hex for both and 332g and 283g front and back weight the z-a0020 you mention are the older bully 2.2 axles 193 and 181 mm in length and 632 and 573 grams the newer bully2s are all machined instead of cast, a lot lower profile, room for servo between motor and axle housing, better link and shock mounting positions, knuckles predrilled for weights, etc... in short - redesigned with most wanted improvements over the older bullys if you are shopping by price, consider all the costs of the mods as opposed to the initial higher outlay of money . funny --- you get half the weight at twice the cost but 3 times the quality Last edited by cabron; 06-04-2016 at 12:07 PM. |
06-04-2016, 12:27 PM | #5 |
| Re: Bully 2 axle?
Thanxs. Won't buy them then. The seller claims that the axles are bully 2, but the number and the look of the casing dosen't match.
06-04-2016, 12:31 PM | #6 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
| Re: Bully 2 axle?
Bully 2's are the way to go, no mods needed at all for a great comp axle. The link/shock adjustments you can make on these is just awesome and don't require any custom fab work unlike some other axles on the market. |
Bully 2 axle? - Similar Threads | ||||
Bully Axle Help For Bully/Wraith | Mikey307 | RC4WD Bully | 3 | 03-29-2013 07:49 AM |
Bully axle ?s | laxjj14 | Superclass Crawlers | 1 | 03-25-2012 11:11 PM |
bully axle | crawlhog | RC4WD Bully | 4 | 07-23-2010 05:04 PM |
