05-13-2017, 01:59 PM | #41 |
Quarry Creeper Join Date: Dec 2016 Location: westlerly
| Re: What battery for Bully 2 RTR
Traxxas tmaxx steering arm bushings work great for replacing the small bearings. Robbob showed me that trick. I had some bearing troubles with mine. But they definitely weren't normal! Haha
05-13-2017, 02:15 PM | #42 |
Quarry Creeper Join Date: Apr 2012 Location: So. Cal.
| Re: What battery for Bully 2 RTR Hey I was looking at your rig again, are those motor skids the 5 hour energy ones? Did you glue them on?
05-13-2017, 02:20 PM | #43 | |
| Re: What battery for Bully 2 RTR Quote:
05-13-2017, 02:24 PM | #44 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: What battery for Bully 2 RTR |
05-13-2017, 02:34 PM | #45 |
I'll post up a few practice comps during the summer but very early in the morning. I usually get 1-4 drivers. Practice and leave when it starts getting hot.
05-13-2017, 04:29 PM | #46 |
05-13-2017, 09:29 PM | #47 |
| Re: What battery for Bully 2 RTR Ok I bought the 500mah version of these, should I run a Lipo Alarm on em? I have a couple of those cheap RPP alarms somewhere around here 🤔
05-13-2017, 10:01 PM | #48 |
Factory esc ? Yes it doesn't have a lipo cutoff lvc I bought one for that reason Hang up and Drive |
05-14-2017, 04:53 AM | #49 |
The wp 1040 or the ae-5 does have a lvc if you end up swapping
05-14-2017, 10:15 AM | #50 | |
You can run a lipo alarm or only run the 500mah for 10min per pack. But if you have a Lipo alarm run it to find out how long you can actually run a 500mah lipo for. | |
05-14-2017, 10:39 AM | #51 |
11-09-2017, 09:21 AM | #52 |
Quarry Creeper Join Date: Mar 2007 Location: winchester
any opinion on this battery? it seems to fit the bill, I would just need to put a deans connector on it. https://www.amazon.com/Great-Planes-...+planes+3s+600 thanks for the help!!! |
11-09-2017, 09:42 AM | #53 |
It will work. Most run between 450 and 800, due to size and run time. If comping you will want a small battery, for just fun, the bigger ones give longer run times. I’m odd I run an 800 and love them Hang up and Drive |
11-09-2017, 10:58 AM | #54 |
okay I'm back from the LHS with my cc bec programmed to output 7.4v. They didn't have a battery small enough so I'm going to pull the trigger on the great planes one. Last question for you folks is can the xr4 receiver handle 7.4v input? thanks!!! |
What battery for Bully 2 RTR - Similar Threads | ||||
MK42 RTR VS Bully RTR | BIG T | RC4WD Bully | 16 | 11-25-2010 07:00 AM |
