Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: What’s your favorite brand shock oil?
Old 11-05-2020, 05:33 PM   #1
Default What’s your favorite brand shock oil?
Team Associated, Losi, etc. I’m going to need to fill up my new Dravtech’s when they get here and am wondering what you guys like as I’m shopping around for shock oil.
cloudswimmer is offline   Reply With Quote
Old 11-05-2020, 06:32 PM   #2
Default Re: What’s your favorite brand shock oil?
I wouldn't overthink this, the only real difference will be price and the CST or WT. CST and WT values aren’t directly comparable from brand to brand, so it’s good to stick to one brand for consistency.
I usually go for Team associated oil because theres a good variety of weights and its usually in stock at RPP or Amain.
HumboldtEF is offline   Reply With Quote
Old 11-06-2020, 11:14 AM   #3
I found some Traxxas oil in 30wt which is what I want, and I like its long nose filler tube, so what your saying is it doesn’t really matter when it comes to Silicone shock oil .. just get what you can get?
Old 11-06-2020, 02:38 PM   #4
Exactly, shock oil is shock oil. As long as it's silicone it doesn't matter what brand it is.
I've used Traxxas, Gmade, Axial (all 30wt) in the past and I keep a few different grades of the Team Associated (30-80wt) stuff around because that's what my local shop carries.
QuesoDelDiablo is offline   Reply With Quote
Old 11-06-2020, 03:22 PM   #5
Gold Star Baby!
Topher Builds's Avatar
The only thing I’d recommend is if you’re wanting to really fine tune with specific weights, then to stick to one brand. Only becuase the ratings can be a little inconsistent between each. Otherwise there’s not much of a reason I’m aware of to lean towards any one brand. I tend to stick with team associated or losi, mostly Losi, as it seems to be commonly available.
Topher Builds is offline   Reply With Quote
Old 11-06-2020, 04:16 PM   #6
I use Lucas. It’s oil.
Phildirt is offline   Reply With Quote
Old 11-06-2020, 04:20 PM   #7
I use team associated. Its made by Lucas and has the conventional weight and centistroke measurement right on it. I stock between 35 and 80w in 5w increments, both because I have a small fleet to attend to, and I like tinkering and tuning.
meatmonkey is offline   Reply With Quote
What’s your favorite brand shock oil? - Similar Threads
motor oil as a shock oil? Mr.JayDeeM General Crawlers 10 09-02-2012 10:59 PM
Shock oil and shock spring help entropy General Crawlers 10 01-29-2011 08:40 AM
best shock oil and gear oil j4k3 Axial SCX-10 2 07-26-2010 12:48 PM
Shock oil LST022752 HPI Wheely King 11 11-13-2007 05:44 PM
your favorite aluminum shock?? newie General Crawlers 9 08-18-2005 12:09 PM
