Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Clockable C's?
Old 10-23-2021, 05:25 PM   #1
Default Clockable C's?
I've been into crawlers for a couple years now. Have a Capra/Alcista conversion, a Class 2, and a scaler.
Just ordered a Bully II. In the description it mentions "clockable C's". I'm unfamiliar with that term. What exactly is it?
Thanks
BR549 is offline   Reply With Quote
Old 10-23-2021, 05:42 PM   #2
Default Re: Clockable C's?
It means you can adjust the axles for mor clearance
imbler2 is offline   Reply With Quote
Old 10-23-2021, 06:12 PM   #3
Thank you sir!
Old 10-23-2021, 06:44 PM   #4
Clocking a C-hub will give you more castor, the C-hub is slotted so it can be rotated back. More castor can improve turning and in some situations aid in gripping the top of a ledge while turning.
I think the amount of castor you add is a preference thing, I tend to add as much as I can.
This wont effect ground clearance.
Castor will angle the tires over when turning.
HumboldtEF is offline   Reply With Quote
Old 10-26-2021, 06:05 PM   #5
Thanks, the picture helps a lot. I'll have to experiment with it on the rocks.
Old 11-25-2021, 02:45 AM   #6
I joined the Band!
The photo explains a lot, thanks for sharing it.
Bacardi William is offline   Reply With Quote
Clockable C's? - Similar Threads
Clockable C-Hubs jeepgod Axial SCX-10 6 09-14-2012 11:28 PM
Witch clockable c Crawlwell Axial AX-10 Scorpion 20 11-28-2010 06:22 AM
clockable c hubs foolish 1 Axial AX-10 Scorpion 0 08-30-2010 10:29 PM
clockable c"s ? patiller Axial AX-10 Scorpion 19 01-02-2010 08:48 PM
