Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Bully 2 kit landed yesterday
Old 01-10-2023, 03:32 PM   #1
Default Bully 2 kit landed yesterday
Well, my Bully 2 kit has landed! I started the assembly last night. Quality of everything in the box seems to be spot on. Only issue I had was on one of the pinion gears. The set screw was stuck and then wouldn’t set deep enough to hold it on the shaft. With some heat and persistence, that was worked out. I’m starting on the electronics now and then some paint.
BEC is the only part still on its way and it’s due here tomorrow. Pics to follow when she’s up and running.
Runnin2live is offline   Reply With Quote
Old 01-11-2023, 07:11 AM   #2
Default Re: Bully 2 kit landed yesterday
Well, I was going to wait until the BEC got here and wired up before I tested it, BUT I was too close. So I rough ran the motor wiring and used the 3.5 mm plugs to connect to the esc. Grabbed my older Kyosho Tx/rx. Plugged everything up and my rx was dead. So I’m glad I tried and didn’t wait. I ordered a new flysky last night and it should be here Thursday.
I could rob anoth Tx/rx but patience is winning for now. I am going to go ahead and solder all my motor wiring in place and install the BEC when it comes in today.
Old 01-11-2023, 02:26 PM   #3
Ots
Sounds like you got the kit, so what motors are you running?
Ots is offline   Reply With Quote
Old 01-12-2023, 05:40 AM   #4
I went with the reedy radon 2 16t. I friend of mine runs those and has had good luck with them. We will see
Old 01-12-2023, 03:41 PM   #5
Ots
I did Holmes TorqueMaster 540 45T's and they are smooth!
Old 01-12-2023, 06:21 PM   #6
Good stuff. I got my new radio in and going to be testing soon. Hopefully these are nice and smooth as well.
Old 01-12-2023, 07:54 PM   #7
Make sure you go through the gear boxes and loctite all the screws. The kit is famous for not doing that.
Good luck. It’s strong. Mine is old and still running.
xxlostonexx is offline   Reply With Quote
Old 01-12-2023, 09:00 PM   #8
Thanks for that @xxlostonexx. I read that a few times and I have it all done with loctite.
I gave it a little 20 minute run, got the epa’s set for the steering and a first pass adjustment on setting the drag brake. More for tomorrow. Still some tweaking I’m sure.
Old 01-14-2023, 02:14 PM   #9
I ran a few batteries through it yesterday and as I was expecting, it is a beast! I made the decision to start without the dig and I do already wish I would have gone with it. Now I just need to decide between the dig switch or going with a mini dual esc
Old 01-31-2023, 09:26 AM   #10
Bully 2 kit landed yesterday - Similar Threads
Stock 10.2 kit in comp yesterday scaled Axial SCX10 II 3 05-14-2019 02:20 PM
The Yeti has landed. Battery question rstekeur Axial Yeti 13 05-09-2016 06:22 AM
Plane landed on top of Semi JasonInAugusta Chit Chat 1 12-10-2004 03:42 PM
