Thread: tf2 trans
Old 03-04-2012, 10:14 AM   #1
Default tf2 trans
did a search but may have over looked it. does the trans have just hi and low ranger or is there a neutral position between the 2 speeds. the reason i ask is that i plan to use my dx3s to shift, and as we all know it only has a 2 position 3rd chanel?
stick-boy-rick is offline   Reply With Quote
Old 03-04-2012, 10:50 AM   #2
REST IN ALOHA CHIP
YoUnG_vErSiOn's Avatar
Default Re: tf2 trans
speed, no intended neutral...but there is a dead spot between. all 2 speeds have it..the full cycle between 1st and second gear relates to about a 2" travel from point a(1st) to point b(2nd) so you should be fine as long as you setup you endpoints.
YoUnG_vErSiOn is offline   Reply With Quote
Old 03-04-2012, 10:59 AM   #3
I Just set my Dx3c to use the switch as 2 position and it shifts fine.
I had to get the epa just right but it works no problems
Dready is offline   Reply With Quote
Old 03-04-2012, 01:52 PM   #4
thanks guys, now i just have to talk myself into selling my wraith to fund TF2. the wraith is cool but i'm more into the "careful crawling" than the "point and shoot" type.
Old 03-05-2012, 04:53 AM   #5
This is corect. If there wasn't a small neutral spot the tranny would be in two gears at the same time and cause a serious problem.
Katan is offline   Reply With Quote
tf2 trans - Similar Threads
Slowbro's TF2 Slowbro RC4WD Trail Finder 2 54 02-13-2015 02:32 PM
Neil's Premature TF2 neillarson RC4WD Trail Finder 2 47 05-17-2012 08:41 PM
TF2 Leafs ? ozace RC4WD Trail Finder 2 2 03-02-2012 04:07 PM
Tf2 Steering blumaro RC4WD Trail Finder 2 5 02-29-2012 03:23 PM
