06-22-2012, 06:38 PM | #1 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
| RC4WD Z-S0027 Gear set
I wrecked my output shafts on my axles (long story) and bought replacements and these arrived Z-S0027 Yota 1/10 Axle Ring & Pinion Gears. They were a tad smaller and I assume that makes them faster? Anyways after putting the truck back together it's a bit speedier now not a bad thing but was just wondering if this is the stock part or a upgrade? (waiting for a reply for RC4WD via email)
06-22-2012, 10:02 PM | #2 |
Pebble Pounder Join Date: Oct 2008 Location: mid state
| Re: RC4WD Z-S0027 Gear set
"This is a stock replacement ring and pinion gears for Yota Axle (Part # Z-A0074, Z-A0075,Z-A0058,Z-A0061,Z-A0059,Z-A0036)" thats what rc4wd web site says so im guessing its just the one size fits all applications for replacement parts? |
06-23-2012, 08:10 PM | #3 |
| Re: RC4WD Z-S0027 Gear set The only difference is they are slightly smaller in size and the output shafts are not flat on both sides and the stock grub screws do not go all the way through the shaft like the stock ones |
06-24-2012, 06:49 AM | #4 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
Why does it have to be flat on both sides? If your grub screw doesn't fit drill it out to make it fit or find a different screw.
06-25-2012, 11:50 AM | #5 |
| Re: RC4WD Z-S0027 Gear set |
06-25-2012, 01:11 PM | #6 |
06-25-2012, 03:15 PM | #7 | |
| Re: RC4WD Z-S0027 Gear set Quote:
On another topic if you guys have not checked the screws on the axle I would give them a once over with your allen wrench. A few on the axle housing and pumpkin were only finger tight. So far so good on the replacement gears | |
06-26-2012, 12:23 AM | #8 |
Pebble Pounder Join Date: Jun 2011 Location: Rio Brisbanero Australia
I just ordered a set I,m hoping there stronger than the originals , which appear to be made out of heat treated Blu Tack |
06-28-2012, 11:47 AM | #9 |
RC4WD Z-S0027 Gear set - Similar Threads | ||||
Axial HD Beveled Gear Set VS Axial HD Gear Set? | Grouper | Axial AX-10 Scorpion | 26 | 02-22-2013 07:40 PM |
RC4WD Hardened Steel gear set UnObtainium??? | DiggyStyle | Axial XR10 | 24 | 05-12-2012 12:20 PM |
Gear set | vegas1973 | Axial XR10 | 9 | 03-14-2011 04:05 PM |
