07-03-2012, 03:25 PM | #1 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| New bumper for my TF2
Loving my TF2 while hating it's plastic bumpers, I ordered up a bumper from RCMODELex. When it arrived yesterday, I could see it wasn't made for the TF2 chassis. So with my limited fabrication skills and no idea on how I was going to make it work, I started out this morning to see what I could do. I ended up using an aluminum RC4WD bumper mount that was already on the truck, a pair of Blue Monkey chassis lift blocks to raise the bumper height, and some 3mm button head screws and nylock nuts. Also, the 3racing winch mounting plate fits perfectly in the cut out in the bumper. The bumper also comes with D ring mounts and mounting tabs for two lights. I'll need to give the bumper another coat of black paint to hide the scratches I made while doing the mock up. Oh, in case your wondering, the bumper is metal and must weigh at least a half a pound. I'll weigh it when I tear it down to repaint. The last two photo's are how I mounted the bumper. First, I used the RC4WD #1 metal bumper that was on the truck. The long brackets you see are what comes with the bumper from RCMODELex. I mounted the end with the elongated holes to mount to the RC4WD mount where the existing holes are provided for the holes that the long set screws go through to mount the plastic bumper. I did this so I could slide the bumper forward or backward to get the distance from the front of the truck that I wanted. As you can see, I used Blue Monkey chassis lift blocks to raise the brackets supplied with the RCModelex bumper. Next I found the center line of the bumper and simply drilled four holes in the new bumper to mount it to the bumper. I used button head cap screws and lock nuts to do this. I am going to use longer screws so that they go completely through the holes in the RC4WD bumper mount and then put a lock nut on each screw. I hope my explanation was clear. I'm sure those of you with proper tools and material will come up with a better way if you decide to use this bumper. Just so you will all know, the bumper weights 10.8 oz as per my postal scale. Last edited by raceeng18; 07-05-2012 at 10:36 AM. Reason: more photo's |
07-03-2012, 05:16 PM | #2 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
| Re: New bumper for my TF2
Looks beefy |
07-03-2012, 09:39 PM | #3 |
Pebble Pounder Join Date: Oct 2008 Location: mid state
looks awesome. i just got the same bumper on friday. i didnt check to see how it will mount but i was happy that it was wider that the body. could you post pics of you mounting system so i can get an idea of how i might go about mounting mine. and it looks fn sweet on your truck. thanks bob |
07-03-2012, 10:47 PM | #4 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Looks killer....is that the Hillux bumper ?
07-03-2012, 11:21 PM | #5 |
Quarry Creeper Join Date: Jun 2012 Location: Vancouver, WA
Was looking at the wrong product. Thought you spent $800 for that! I am ordering one up myself. Looks awesome. Last edited by t3yf5g; 07-03-2012 at 11:24 PM. |
07-04-2012, 06:31 AM | #6 |
| Re: New bumper for my TF2 |
07-04-2012, 07:07 AM | #7 |
Too bad it's so heavy, there's enough weight up front already Looks awesome though |
07-04-2012, 10:34 AM | #8 |
Pebble Pounder Join Date: Jan 2011 Location: Peace and Quiet
PICS of the mount and the bumper model number would be great.. TY
07-04-2012, 11:32 AM | #9 |
The bumper is the Defender ARB, BU-0095. I'll get some pictures of the mount ( which I'm going to look at re-doing) when I tear it all down for re-paint OK.
07-04-2012, 07:47 PM | #10 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
Looks good! nice fab skills getting it to work!
07-05-2012, 05:19 AM | #11 |
I wrote to RCMODELex about the Hilux bumper. Their response was that the Hilux bumper they sell needs modification to fit the TF2 chassis as well.
07-05-2012, 04:01 PM | #12 |
Postclanker, I'm finding the extra weight up front to be to my advantage when it comes to climbing. As you can see in my photo, the front of the truck is still level. I haven't noticed or heard the front shocks bottoming out as yet and I am not running the internal springs up front. Time will tell I guess. Oh, what I have noticed is that I now have to be cognizant of my approach angle to an object I want to go over. This bumper protrudes just a little more. I still have some room to move the bumper towards the grill a little more without it touching, I may give that a try too.
07-05-2012, 08:09 PM | #13 | |
| Re: New bumper for my TF2 Quote:
07-05-2012, 09:18 PM | #14 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
07-06-2012, 08:00 AM | #15 |
Me too. ... |
07-06-2012, 09:11 AM | #16 |
| Re: New bumper for my TF2 Tough Armor Rear Bumper Mount for Trail Finder Chassis imgoingto try to mod something like this to get my helix bumper to fit my tf2. |
07-09-2012, 09:55 PM | #17 |
RCC Addict Join Date: Feb 2011 Location: York
Here's how I made my mount for my RCModelex ARB (well Nate's mount and bumper for my old TF2 LOL!) this is before the holes were drilled and paint...the plates run back between the frame rails and use the existing braces and holes on the chassis. I used the same style mount on the bumper I fabbed on the truck originally. This uses the same idea but i welded the horns that RCmodelex includes, onto the stainless plates. My friend Adam thought it would be nice to take a pic of the non-aitcraft welding action while I'm on the clock |
07-10-2012, 05:19 AM | #18 |
Can you share pic of this mounted on the tf2 chassis.Thanks
07-10-2012, 06:59 AM | #19 |
07-10-2012, 07:09 AM | #20 |
that picture of you welding tozrovr is awesome. and thats how i was going totry to hook my bumper up but after checking it out it looks as if all i need is like a 2mm or so spacer to mount it to the chassis side rails? i might have to fab up some longer (stock) bumper mounts with slots in them to get the proper spacing to the frontof the grill. |
New bumper for my TF2 - Similar Threads | ||||
Front and rear bumper mounts tf2 | mtgrizzlymn | RC4WD Trail Finder 2 | 4 | 05-27-2012 05:56 AM |
RC4WD Aluminum Bumper Mounts for the TF2 (Just Released) | Rckcrwlr | RC4WD Trail Finder 2 | 8 | 05-16-2012 04:41 AM |
