Thread: rear shocks hit the u bolts
Old 07-18-2012, 11:10 PM   #1
Default rear shocks hit the u bolts
i installed u bolts on the tf2 and up front they are great but in the rear the shocks hit the nut to the u bolts and bind up the suspension. i need to move the lower shock mount to the top of the axle or on the inside of the leaf spring i was wondering if anyone else was having the same issue?
any advise will be greatly appreciated.
Icer.One is offline   Reply With Quote
Old 07-19-2012, 02:10 AM   #2
ScaleFreak93's Avatar
Default Re: rear shocks hit the u bolts
You should be able to just put a spacer on the shock shaft end and leave it on the bottom of the axle. Check out 1BJB's thread, he did it. Also I think there was another thread on this with a few other fixes.
ScaleFreak93 is offline   Reply With Quote
Old 07-19-2012, 08:14 AM   #3
thanks i looked them up and now know what i gotta do
thanks again
Old 07-19-2012, 08:26 AM   #4
Moderator
badhoopty's Avatar
i used spacers on both ends.
badhoopty is offline   Reply With Quote
Old 07-19-2012, 02:51 PM   #5
so where can I pick up some spacers?
Sparks1337 is offline   Reply With Quote
Old 07-19-2012, 06:20 PM   #6
Sinking with the ship
1BadJeepBruiser's Avatar
Fast eddy are the spacers I used.
Old 07-19-2012, 06:33 PM   #7
rc4wd sells some, your local hobby shop, rpp, horizon. i myself like to get my stuff from my local hobby shop
they just got me a bunch of spacers ranging from 1mm to 6mm.
RC4WD - The Ultimate RC Products
RPP Hobby | Radio Controlled Cars, Trucks, Boats, Helis, Planes, Plastic Models
here are a couple i found. you can also make your own i use a hobby miter box to make mine
that way it comes out even and the right length. the hobby miter box is small so i clamp the alum or delrin tube in it then
use the x-acto saw to cut it.
http://www.amazon.com/s/?ie=UTF8&key...l_8f2rxcn1g6_e
good luck
bob
dybbob is offline   Reply With Quote
Old 07-19-2012, 06:57 PM   #8
You can also use a rodend ball also for a spacer. I'm gonna use a fast eddy aluminum spacer
Old 07-19-2012, 11:10 PM   #9
Here's the set up I copied
Here are the spacers I used
Thanks for all the help
Hope this helps someone else also
Old 07-20-2012, 11:45 AM   #10
I'm definatly getting that spacer kit. I didnt know tfe made that.
thanks
Old 07-20-2012, 03:20 PM   #11
loads of info there! thx everyone.
Old 07-20-2012, 05:25 PM   #12
After spending a crap load on my TF2 I didn't have any money left for nice spacers so I just used some metal ball-ends form an old Tamiy kit and some long screws. I used four in total and still used the kit spacers in the same locations.
It will do for now.
Kenny G is offline   Reply With Quote
Old 07-20-2012, 11:20 PM   #13
I love those spacers the ballends they just plane work and the best part "free" awesome
I have had the spacer kit forever and i keep recycling the spacers put them on one rig then don't need them on another and i just keep putting them back in the box. The box is cool It's like a tiny fishing tackle box it has sections for the different size spacers anyways
Hope this is helping the tf2 community
rear shocks hit the u bolts - Similar Threads
Outboarding Rear Shocks - Not Always a Plus GrimJeeper91 Team Losi Comp Crawler 14 07-12-2014 10:40 PM
bruiser u-bolts fit on yoga axles? home made u-bolts anyone? cydog510 RC4WD Trail Finder 2 4 06-26-2012 12:27 PM
my new links hit my shocks? help BRUSHLESSAX10 Axial AX-10 Scorpion 5 02-22-2008 12:12 AM
Does your tires hit your links or shocks at full steer? bi_eep Axial AX-10 Scorpion 6 02-20-2008 01:51 AM
