11-25-2012, 10:26 AM | #1 |
Rock Crawler Join Date: Sep 2009 Location: Bushnell FL
| XVD Whats your thoughts?
Hey guys whats your thoughts on these are they worth the $40 or sould i spend my $ some where else?
11-25-2012, 11:04 AM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
I just got them for my truck. I'm still doing shakedown runs since I've rebuilt it so maybe 10-15 minutes at a time, after 3 of these runs I only had 3 wheel drive. After tearing the corner down, the inner shaft the holes for the pin were broken out. RC4WD replaced them but I think the problem is the design. They secure that pin with an aluminum sleeve instead of a set screw. That aluminum sleeve takes up space that could be load bearing steel. Sent from my Galaxy Nexus using Xparent ICS Tapatalk 2 |
11-25-2012, 10:30 PM | #3 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
| Re: XVD Whats your thoughts?
I'm running them in my Mog and in my OG tan Yota. So far, no major issues. One upgrade that I would do is replace the drive pin with the dogbone pin from an Axial axle shaft. You will need to grind it down to the correct length (don't get it too hot when grinding). I noticed the stock pin showed a fair amount of wear after a several packs, this was an easy fix. I also wore out the aluminum retaining sleeve due to dirt getting in and chewing it up (I made a new one). Mind you, I was running it in some really sandy, muddy water so... Over all, they are holding up better than I expected, especially on my Yota since it's heavy and gets driven really hard. I just wish they offered a few more degrees of steering. |
XVD Whats your thoughts? - Similar Threads | ||||
Whats your thoughts on this scale crawler?? | nowdedispu | General Scale Talk | 27 | 01-26-2010 01:38 PM |
whats hot, whats not. post good and bad setups and products | TomEGunn | General Crawlers | 9 | 05-28-2009 07:29 PM |
Whats your thoughts on a few crawlers? | ProfitOfDoom | General Crawlers | 5 | 03-09-2009 08:34 AM |
Kimbo Slice Vs Tank Abbot Whats your Thoughts on a Winner? | TheHeadHunter | Chit Chat | 9 | 02-03-2008 08:52 PM |
New World Order. Whats your thoughts | run2jeepn | Chit Chat | 6 | 12-14-2006 01:10 AM |
