10-30-2014, 12:22 AM | #1 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
| creating slightly lower ride height
Ive seen some bulds where the tf2 has been lowered for a more scale ride height/stock appearance but no real details of how its done im not talking lowrider just an 8th of an inch or so all input will be greatly appreciated truck is stock with the exception of 1.55 baja mtzs and a set of red leafs waiting in the wings
10-30-2014, 03:18 AM | #2 |
Rock Crawler Join Date: Sep 2009 Location: Spring, Texas
| Re: creating slightly lower ride height
RC4WD sells a body lift kit for the TF2, but I bet if you turned it upside down it would lower your body as well. Might interfere with the rock sliders. Never seen anyone try it though... |
10-30-2014, 04:55 PM | #3 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
You can tweet your leafs in either direction to increase or lower ride height. The red leafs for sure will allow to sink further sooner than the blacks. Beware though altering ride height with this method alters the wheelbase. You could also mount your leafs under the axle instead of on top. Another trick would be to fit packers inside the shocks so they can't fully extend but this will restrict travel. |
10-31-2014, 06:26 PM | #4 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
Gelande front shock hoops will allow you to lower the front end by up to 12mm with stock shocks. In the rear, you should be able to lower by moving the upper shock mounts inboard. Those two adjustments would have the effect if lowering everything a bit without having to modify the body mounts. The only issue to watch out for would be rubbing the tires. Sent from my iPad using Tapatalk |
10-31-2014, 07:01 PM | #5 |
Thanks for your input guys tire rubbing shouldnt be an issue as I plan to use mickey thompson baja mtz in 1.55 man they are small
creating slightly lower ride height - Similar Threads | ||||
Ride Height | Caswell | Axial Yeti | 0 | 07-22-2014 03:29 PM |
How does one lower ride height | RickM | Axial AX-10 Scorpion | 13 | 04-04-2010 09:12 PM |
Ride height versus max height | Manson | Axial AX-10 Scorpion | 9 | 10-03-2008 01:26 PM |
Lower ride height? | Deezul | Axial AX-10 Scorpion | 3 | 09-07-2008 08:46 PM |
How to lower the ride height? | XPLORx4 | Newbie General | 16 | 08-28-2008 09:28 AM |
