01-21-2015, 02:24 PM | #1 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
| run times on tf2 with lipo
I have access to several 7.4v 1300mah 25c lipos my tf2 is equipped with castle sv3 bec savox wp servo and 45t integy with stock single speed tranny are these batteries worth my time if so what kind of runtime can I roughly expect?
01-21-2015, 03:44 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: run times on tf2 with lipo
You may get about an hour of runtime, of course all depending on how you drive. If you really scale drive with it, maybe close to an hour and a half. Best thing is to try it out. Charge one up, bring a stopwatch and time your runtimes. |
01-21-2015, 04:18 PM | #3 |
| Re: run times on tf2 with lipo Would it be ok or wise to run two of these batteries in parallel?
01-21-2015, 07:22 PM | #4 |
Quarry Creeper Join Date: Nov 2010 Location: Toney/Huntsville, AL
| Re: run times on tf2 with lipo |
01-21-2015, 07:25 PM | #5 |
Rock Crawler Join Date: Jul 2005 Location: Spartanburg
You can run the parallel batteries and have 2 smaller batteries flanking the frame rails. Can actually help with CG and balance of a rig. I will toss a 5000mah 2s in every once in a while and can usually trail till I am ready to pack it up on one pack. |
01-21-2015, 07:50 PM | #6 |
| Re: run times on tf2 with lipo Good point. I didn't even think about the smaller batteries. I've never had any.
01-23-2015, 06:46 PM | #7 |
Pebble Pounder Join Date: Dec 2014 Location: Oshawa
I run two 2cell 5000s in parallel on my stomper. I get 4-5 hours depending on how hard i run it. And i also run a 2cell 8000 on my TF2. I have yet to hit the low cut off with 2 -2 1/2 hour runs on that one. |
01-24-2015, 12:57 AM | #8 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
Ditto here with a 5000 mah 2s 40c Lipo. We usually run 3-ish hours, and I rarely have to swap a pack on it. I would recommend that over 2 packs for simplicity.
01-25-2015, 02:38 AM | #9 |
I use to run 1 battery. But i did some changes and spot were battery use to be don't work anymore for me. On top of that my truck is top heavy. So I ended up putting battery's on my sliders to lower the CG a bit and picked up some extra run time. |
run times on tf2 with lipo - Similar Threads | ||||
Run Times With 5,000 Mah Lipo ? | nitrojunk | Axial SCX-10 | 5 | 05-14-2014 02:07 PM |
3s lipo vs 2s lipo run times? | Sapes | Electronics | 40 | 12-18-2013 07:16 AM |
Losi and Lipo run times | RickM | Losi Mini-Rock Crawler | 4 | 02-07-2010 04:09 PM |
lipo run times? | Tklan Crawler | Electronics | 24 | 10-14-2009 07:49 PM |
10000MAH 3 Cell Lipo? Run Times? | PapaGeno21 | Electronics | 16 | 03-06-2008 06:52 PM |
