01-24-2015, 07:40 PM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: sacramento
| Transmission output shaft upgrade
If you need to replace the output shaft on your transmission you can upgrade to and rc4wd ax2 heavy duty out put shaft AX2 Heavy Duty Output Shaft The tf2 shafts fit both the r3 and the ax2 so the output shaft will fit the r3 transmission in the tf2 I'm using the ax2 heavy duty output on my tf2 transmission and it works great |
Transmission output shaft upgrade - Similar Threads | ||||
SCX10 Transmission Noise/Output Shaft Wobble | CHawk68462 | Axial SCX-10 | 27 | 10-15-2016 09:26 AM |
best way to join a rwvo drive shaft to the output shaft on the axle | TRAV | Kyosho Crawlers | 12 | 01-29-2012 07:37 PM |
transmission output shaft :( | meanbgreen | Axial SCX-10 | 15 | 11-18-2011 02:41 PM |
Broken Transmission output shaft | sbarnesvta | Axial AX-10 Scorpion | 6 | 03-25-2009 01:35 PM |
Transmission output shaft | MaXX_CrAWlER7 | Axial AX-10 Scorpion | 3 | 03-23-2008 07:39 AM |
