01-31-2017, 06:44 PM | #1 |
Pebble Pounder Join Date: Nov 2006 Location: Hanson
| Stripped front axle housing question.
My front axle housing is stripped where the steering knuckles screw on. The axle housing is on back order And I have a competition next weekend. Does anyone have a fix without replacing the axle? I have tried red lock tight before but it doesn't hold. I thought about installing american screws and drilling out the bushings but I figured I would post here first.
01-31-2017, 07:11 PM | #2 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
| Re: Stripped front axle housing question.
Helicoil probably the best bet
02-01-2017, 06:14 AM | #3 |
Newbie Join Date: Dec 2016 Location: Yukon
Paul that's pretty much what I did. I drilled and tapped the housing for an m4 bh screw and drilled the knuckle slightly oversize from the screw. Was just gonna be a quick and dirty fix, but it's held up good enough that I haven't even bothered ordering a replacement.
02-01-2017, 06:51 PM | #4 |
Rock Crawler Join Date: Nov 2014 Location: Dells
Helicoil. A kit should be <$20 on amazon. You want the shortest inserts they make IIRC they're labeled as 0.5 length. Take your time. Use RED threadlock on the helicoil. It will be stronger than the stock axle. |
02-05-2017, 02:27 PM | #5 |
I want to thank everyone for their input and tips. I ended up drilling it out to 4mm and it feels good.
Stripped front axle housing question. - Similar Threads | ||||
Gear teeth stripped in front axle..? | 03mach1 | Axial SCX-10 | 6 | 08-31-2015 06:53 AM |
Using a front axle housing on your rear axle | nstn8 | Axial XR10 | 2 | 10-25-2011 07:32 AM |
