02-21-2018, 02:40 AM | #1 |
Quarry Creeper Join Date: Oct 2012 Location: Oxford
| Yoga 2 axles - More steering angle?
The Yota 2s on the Marlin, do they have more steering angle capability than the yota 1s with xvds or are they the same?. Thanks. |
02-21-2018, 06:43 AM | #2 |
Newbie Join Date: Apr 2012 Location: Stockton
| Re: Yoga 2 axles - More steering angle?
Yes quite a bit more. Sent from my iPad using Tapatalk |
02-21-2018, 12:42 PM | #3 |
| Re: Yota 2 axles - More steering angle?
Hahaha, flipping predictive txt crap... Yoga, the karma choice of all axles!.. |
02-21-2018, 01:19 PM | #4 |
I have modified two V1 housings with great results. Takes some work. VP parts Parts to do the F-Toy. F-Toy axle in front of other modified axle on my TF2 build. |
02-21-2018, 02:45 PM | #5 | |
| Re: Yoga 2 axles - More steering angle? Quote:
I did look at putting some wraith / xr10 bits on an axle a few years back but decided i couldn't be arsed!... Still have some bits to convert an original scx10 axle somewhere.. | |
02-24-2018, 02:16 PM | #6 |
Quarry Creeper Join Date: Jun 2017 Location: St George
Dude that garage is amazing Sent from my iPhone using Tapatalk |
02-24-2018, 04:57 PM | #7 |
Having noticed an obvious link to this info on another thread here are the details from another post with regards to benefits of yota2 over yota1: Default Axle Comparison: Yota 1 vs Yota 2 Have had several questions on the differences between these two axles. Here are some of the differences that I have come up with: Smaller OD tubes Removable diff covers More detailed third member piece Front axle: Case is one piece 8* knuckles Knuckles have two sets of arms so BTA steering is possible Larger/stronger XVD with 45* steering (Yota 1 is 35*) Rear axle: Two shock mount options 45 degrees sounds awesome!!!! |
03-04-2018, 09:41 AM | #8 | |
Wraith/XR bits won't work.. well, they will... They will make the wheel offset way too wide.. Scx is how you keep the right width of the body and axle. | |
03-04-2018, 05:01 PM | #9 | |
To be honest having now looked more and more into it i have found that whilst one could get more steering you would have to widen the track either of the axle or using wider hexes ( which cause other body clearance issues) in order to benefit from it. My regular tf2 with xvds ( so far been ok) can touch the leafs. The Marlin i just got has the next gen axles with xvds which has more angle capability which i'll exploit a bit more using slightly different offset wheels / hexes... Very new to comps but loving this platform and have had good results | |
03-04-2018, 05:15 PM | #10 | |
The reason I went with the mod, was my xvds lasted, maybe, 5 minutes. The first one blew apart and the truck went back on the shelf. Which lead me to do more and more work, on it. Results speak for themselves. Loads of pics in my build thread. | |
03-06-2018, 05:34 AM | #11 | |
Yoga 2 axles - More steering angle? - Similar Threads | ||||
more steering angle please!!!! | roadrunner440-72 | Axial SCX-10 | 4 | 12-17-2016 09:02 PM |
bruiser u-bolts fit on yoga axles? home made u-bolts anyone? | cydog510 | RC4WD Trail Finder 2 | 4 | 06-26-2012 12:27 PM |
Steering angle | BOB8789 | Axial SCX-10 | 6 | 01-13-2012 10:55 PM |
Steering Angle | HiloDB1 | Kyosho Crawlers | 1 | 11-26-2008 11:05 AM |
Steering angle | NeoSlayer888 | Tamiya TLT Crawlers | 3 | 10-29-2005 07:21 PM |
