05-10-2019, 08:15 AM | #41 | |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
| Mountain Expedition Yota. Quote:
Nate with all being said I think the A&M +4 should be the only front hanger offered by them. The version from them fell short. I’m not knocking the company whatsoever. I truly appreciate small companies that support our hobby and I feel they have been fantastic overall with all their offerings for this amazing platform (TF2). The material and amount used isn’t the issue IMO. I actually used slightly thicker material to prevent any deflection and prevent possible binding. I due think the inner L shaped mount is the culprit. The size of the holes and size of the hardware combined with the L inner mount (in my experience) is the issue. It allows the inner L to shift causing the bind. I discovered this early during assembly and remedied it with welding the cross brace/rad support/bumper mount to hold everything together. My brackets are the same both inner and outer. I understand the reason they produce theirs this way. It allows for a stock front bumper to be mounted. Will be in touch. Sent from my iPhone using Tapatalk | |
06-08-2019, 03:05 PM | #42 |
| Re: Mountain Expedition Yota.
Little update to report. I finally got some paint on the yota, new Marlin grille and spent the last hour or so welding up a new front bumper. I’m liking the clean look and cannot decide if I need to add a 2 bend stinger of sorts. At this point all rock protection is done. Need to focus on the interior and adding the electronics! Sent from my iPhone using Tapatalk |
06-08-2019, 06:09 PM | #43 |
I like simple design, but maybe side wrap on bumper and lower triangulation pieces? My 1:1 Toyota had narrowed and reinforced Smittybilt double tube front bumper with addon lower ramp like pieces that tied in to front spring perches.
06-12-2019, 12:18 PM | #44 |
Newbie Join Date: Apr 2019 Location: edinburgh
Guys, quick question. Like this thread points out: there is barely enough axle stub sticking out for the nylon of the axle not to get a bite on. Are the Axial hexes a direct swap? How much thinner are they? thanks, mark |
10-24-2019, 09:29 AM | #45 | |
Rock Stacker Join Date: Mar 2015 Location: Mahopac
| Re: Mountain Expedition Yota. Quote:
We make the kit as versatile as possible. Hence the inside "L" brackets. They have to accommodate the stock bumper cross members. If that wasn't there, we would just supply two outers and be done. On our class 1 rig we run a scale winch behind the grill. It mounts ontop of the cross member. Once the cross member is in, everything locks in place. We leave a bit of material on there to help protect the leaf. It could be smaller, but I like the fact that there's plenty of strength. Binding is rare. And if there is any binding due to an extreme leaf setup, they can be bent out a touch at the back. The original shackle kit works well with the kit, 4 door and blazer. But for the marlin or anyone looking to stretch the front out, we have the +4 option. This is also what we use as the base for our comp bumpers. https://aandmgarage.com/shop?olsPage...ackle-reversal Again.. appreciate the feedback. And killer bumper! nice work! | |
10-24-2019, 09:42 AM | #46 | |
Since December 2018 we've been supplying small spacers, different hardware and instructions. No more drilling. It took a bit of time, but one of our partners was able to get the parts made. Sorry you had to replace the chassis. PM me if you need anything. Happy to take care of you on some parts. Bert. | |
10-25-2019, 12:04 PM | #47 | |
Good to hear you've updated the design, I like the spacer setup much better, the +4mm is a sweet option too! It happens, appreciate your generous offer, but I'm good. Looking forward to seeing more cool TF2 parts from you! Thanks, Nate Brotha Bananaclip, good day to you! Is your front bumpah done yet? | |
02-08-2020, 02:02 PM | #48 |
Nate.... front bumper is done! Lol. Sorry for the neglect on posting updates. I’ve been in the middle of multiple builds. I am happy to say that the TF2 is done minus a few scale details and some paint in the box. I pulled the seat and driver out to run the electronics so I will have to toss those in for some pics. I’m also going to pull a leaf out of the pack to drop the overall height. Oh I need to slap on the inner fenders a buddy of mine printed for the rig. More to come. Sent from my iPhone using Tapatalk |
02-08-2020, 03:12 PM | #49 |
Looks great, love the bumpers too! Have you wheeled out with the +4mm front spring reversal setup? |
02-08-2020, 06:41 PM | #50 |
Thank you Nate. This rig has never been ran but I have ran the extended reversal on a few of my TF2’s. It works very well. I want to get my ride height down a tad on this one and it’s ready to role! Sent from my iPhone using Tapatalk |
04-07-2020, 07:10 AM | #51 |
I took the TF2 out for a shake down run. The little truck did very well in fact. I chose 1.55 Berserkers with dual stage CI foams mounted on 1.7 Steelies for the testing and again was super happy with the pitbull traction. The suspension took no time to beak in and that is my next focus. I will most likely add another leaf to each pack. Few pics. Sent from my iPhone using Tapatalk Last edited by Bananaclip; 04-15-2020 at 09:53 PM. |
Mountain Expedition Yota. - Similar Threads | ||||
Duce and a half tf2. Rc semi /1 ton axle swap for use with tf2 | bent_hinge_pin | RC4WD Trail Finder 2 | 5 | 07-05-2018 08:24 PM |
