Thread: R3 2sp vs. R3 single sp. pro’s and cons
Old 08-09-2020, 02:00 PM   #1
Default R3 2sp vs. R3 single sp. pro’s and cons
Trying to decide if I want to replace the 2sp in my TF2 with the single speed transmission. Compared to my Gelande 2 the TF2 spur gear sure travels a lot before engaging. A few things to note.
I never use 2nd gear so it means nothing to me. I’m more about the low slow control.
Also if relevant, will soon be transferring all parts to a LWB chassis I have on order in prep for the 87’ Toyota body
Thanks.
Fishcharger is offline   Reply With Quote
Old 08-11-2020, 12:24 AM   #2
Default Re: R3 2sp vs. R3 single sp. pro’s and cons
I'm going to order a tf2 kit soon and it sounds like the 2speed has a lot of slop/free play. If your about slow speed control, the single speed will be much better. You ought to also fair a bit of $ for the 2 speed.
dirk379 is offline   Reply With Quote
Old 08-11-2020, 02:49 AM   #3
Cool man thanks. Just got it on order. Anyone interested in a RC4WD R3 2sp transmission?
Old 08-14-2020, 06:52 AM   #4
Yes there is a lot of slop in the 2 speed, mine is locked in the lower gear and just going from forward to reverse the spur moves almost a quarter turn to get the slop out. A single speed is in my future
Big Bill is offline   Reply With Quote
Old 01-11-2021, 05:03 PM   #5
I have a 2sp kit coming because i wanted to gear it way down so the high gear was an over all crawl and trail gear. Then low gear would be like a granny gear for that super slow crawl. Disappointing to hear the 2sp trans has so much slop even when locked into a gear. Whats the play coming from? But be a way to take up that backlash.
mach2nh is offline   Reply With Quote
R3 2sp vs. R3 single sp. pro’s and cons - Similar Threads
Pros/Cons: Mamba X vs. HH TrailMaster BLE Pro OzarkCrawler Electronics 11 03-30-2018 06:58 AM
Single motor? Or Axle mount? Pro's and cons. The Jackalope Newbie General 41 10-03-2013 06:09 PM
pro and cons on honcho damige jnr Axial SCX-10 21 04-06-2010 06:55 PM
newb here....tuber ax-10 pro and cons akxj Axial AX-10 Scorpion 10 07-17-2008 12:13 PM
