Like Tree2Likes
Thread: Rckcrwlr's RC4WD Predator Tracks Unleashed
Old 12-13-2011, 12:31 PM   #21
Originally Posted by THuhtamaki View Post
How is the track tension adjusted? If the frontmost wheel pair is shimmed, does the track set come with different thickness shimms?
We will offer shims if it becomes necessary. From what we have seen in testing it has not been an issue.
Katan is offline   Reply With Quote
Old 12-13-2011, 01:37 PM   #22
Originally Posted by soutthpaw View Post
can you post up some install close ups. I am curious what alows the tracks to pivot but not flip completely over?what keeps them from doing wheelies onto the rear end of the track each time you accelerate?
SO I am guessing these would not be comp legal? due to not being 1.9 or 2.2? would be fun addition to comps though
They have an tip on the fitting kits that fit inside the tracks. Its a pretty easy setup. Just requires some major work adapting to each type of axle out there.
I am sure some other vendors will have fitting kits as well. I hope others will jump in.
Racer4Life is offline   Reply With Quote
Old 12-13-2011, 01:50 PM   #23
even though they are not exactly scaler rigs, is there any word on if an adation kit is being considered for a 4WD stampede?
STEEL_CITY_CRAWLER is offline   Reply With Quote
Old 12-13-2011, 02:41 PM   #24
ALEX CHITPLOW BABY!
Lobonyc's Avatar
WOW i just noticed the other "predator tracks" thread
MaxxTrack Rubber Track Conversion Systems
Although i know that these were prototypes they would have been AWESOME times 10 had they remained bare aluminum as they resemble the tracks used in the TERMINATOR movies.
Hard anodized just makes them a mere AWESOME times 9.5
Can't wait for the set i ordered to arrive....
My Wife is gonna kill me....
Lobonyc is offline   Reply With Quote
Old 12-13-2011, 03:34 PM   #25
~The Scale Shop~
STANG KILLA SS's Avatar
awesome! i cant wait for a silver or black version, and different tread patterns to be offered!
STANG KILLA SS is offline   Reply With Quote
Old 12-14-2011, 04:44 AM   #26
Nobody
Cordwood's Avatar
Someone should glue some 1.9 pit bull treads on the tracks.
Cordwood is offline   Reply With Quote
Old 12-20-2011, 11:18 AM   #27
Default Re: Rckcrwlr's RC4WD Predator Tracks Unleashed
These things are awesome!!! Great job.
GMtech1 is offline   Reply With Quote
Old 12-20-2011, 03:11 PM   #28
BTF
BTF's Avatar
OK i got to have a set of these....................... let me go over and order some now
BTF is offline   Reply With Quote
Old 12-23-2011, 07:19 PM   #29
RC4WD Team Mgr
Rckcrwlr's Avatar
So you got your Predator Tracks and drooled on them...
What next:
Well the initial thought would be to get them mounted up and run them but....
STOP!!!
There are some things that you need to do to ensure a long lasting and enjoyable experience with them.
Thread Lock all the screws that thread into aluminum. Use a Medium (Blue) Thread Lock to avoid them backing out. As the picture below with show...there are a total of 11 screws on each track...yeap, 44 total screws. And the cap that covers the wheel nut.
Now that you did that, let them dry and then have at it. Make sure that all the parts move freely. Sometimes you can get thread lock on the bushings and will bind it up. if that happens, just move them to break it loose.
After the Run
Now you just spent the day tracking around in the snow and mud and you come home. Just throw it on the shelf for the next time...NOT!!!
Keeping these working at their best requires a little maintenance after a run also.
Take them off the rig: This will make it easier to do maintenance.
Remove all the large debris: This can include rocks, chunks of mud/grass, sticks, etc.
Remove the tracks: This is a good time to check for any wear, cuts or deterioration. Also, spray them with Simple Green or another cleaner and scrub them so they are ready to go.
Clean well: I use a tooth brush and make sure that I get all the dirt off the grooves and track wheels.
Get rid of all water: Using Motor Cleaner, spray them down to ensure that you have displaced all the water.
Check all the screws: Make sure that your Thread Lock is holding up.
Bearing Maintenance: Bearings do not like water or snow. Make sure that you have checked them good and there is no residual water in them.
Lube them up: Using bearing oil or a good dry lube. It keeps the parts moving freely and with being dry, it doesn't hold onto dirt and grime. I like CowRC's Moo-Slick (I was not paid for the endorsement )...seriously, I like it because it drys with no heavy oil coating.
Below is a diagram on where you need to thread lock and oil. Please note that the lower track wheels are held on with lock nuts.
Now put it on the shelf until next time...and you will have endless fun with them.
Rckcrwlr is offline   Reply With Quote
Old 12-24-2011, 10:25 PM   #30
These are going to make my north Dakota winter so much more bearable! Patiently waiting for my email notification... Thanks for another great product RC4WD!!!
701 Technique is offline   Reply With Quote
Old 12-25-2011, 11:23 PM   #31
Very nice work John.
Thanks
Old 12-26-2011, 04:49 AM   #32
RC4WD Team Mgr
Rckcrwlr's Avatar
Thanks
thanks Boss... LOL
Old 12-29-2011, 06:08 AM   #33
Levesque87's Avatar
Whats the turn around from order.. to shipping.
Levesque87 is offline   Reply With Quote
Old 12-29-2011, 04:32 PM   #34
When we have them in stock. 1-2 days.
Old 12-30-2011, 05:43 AM   #35
Any idea when you're going to have more in stock?
markturbo is offline   Reply With Quote
Old 12-30-2011, 09:29 PM   #36
I am going out on a limb and saying two weeks. That is just a guess though. Many things can happen.
Old 01-03-2012, 07:40 PM   #37
RC4WD Team Mgr
Rckcrwlr's Avatar
Our 1 to 3 inches of snow forecast, ended up being about 4 or 5 inches...
JK was calling me all day so I got it out this afternoon....
Definitely, with this deep of snow, a lighter rig with more cowbell would run better but with a little patience and learning the throttle, I was able to plow through the snow that was over the hood...
At one point I plowed myself a wall in front of me...I just backed up a little, put the hammer down and blew right through it.
I may try them on a lighter rig with a little more speed.
Old 01-03-2012, 08:44 PM   #38
old man 52's Avatar
Are you following me Like i said ,we need video
old man 52 is offline   Reply With Quote
Old 01-03-2012, 09:16 PM   #39
And we need them available because I'm freaking out man! Got a truck ready to go and I want a set of these so bad it's driving me crazy!!
Old 01-04-2012, 03:45 AM   #40
RC4WD Team Mgr
Rckcrwlr's Avatar
Make sure you are the notify when available...you will get an email as soon as they are in stock...and you better move fast,
You may edit your posts
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
