12-14-2009, 04:49 PM | #221 |
Quarry Creeper Join Date: Sep 2009 Location: west sacramento
damn nice Rig |
12-14-2009, 07:42 PM | #222 | |
Rock Stacker Join Date: Oct 2009 Location: Jersey
Anyone know of a 9t pinion available that would work? Jsowens...what's the ID of that 10t pinion from rc4wd? Last edited by bl8zn; 12-14-2009 at 07:56 PM. | |
12-14-2009, 08:31 PM | #223 |
Newbie Join Date: Feb 2009 Location: Glendale
| RS-10 Video Link
I would like to thank jsowens for his help posting pics mods: Custom battery pack lowered esc tray inverted upper arm mount relocated front shocks and removed springs lowered and moved body foward I recieved my new links so bending will begin shortly. Definitely needs stronger servos Here's a video I made today. let me know what you think. http://www.youtube.com/watch?v=1F_FzaCmc10 |
12-15-2009, 06:33 AM | #224 |
Rock Crawler Join Date: Dec 2005 Location: Huntertown, In
Heres a couple updated pics of my RS10. Just added DNA Thrashers and HB Rovers and reworked the suspension alittle. Heres a teaser of my 2010 comp body!! |
12-15-2009, 08:10 AM | #225 | |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
http://www.rc4wdstore.com/2/product_...roducts_id=197 | |
12-15-2009, 07:37 PM | #226 |
Newbie Join Date: Nov 2009 Location: Asheville, NC
12-15-2009, 11:07 PM | #227 |
Pebble Pounder Join Date: May 2007 Location: Little Rock
My RS10 is on the way and I have Rover whites with foams on the way also. Do I need to glue the tires since it has beadlocks or are these fake. Is there any type of starting point that I can use to start with wheel weights. And are the venom creeper or Ax10 (bent link) stage 2 kits compatable with these? I dont like the height of the body and want it lower. http://www.ckrccrawlers.com/shop/ind...oducts_id=1641 or http://www.ckrccrawlers.com/shop/ind...roducts_id=575 Got another question. Is there anyway to disable the annoying sound the controller makes without opening it up and snipping the wires to the speaker. Last edited by house_Fly; 12-16-2009 at 12:35 AM. |
12-16-2009, 07:04 AM | #228 | |
12-16-2009, 08:55 AM | #229 | |
Did the humming stop for those of you that did motor swaps? If so what's causing it with the stock motors or just what's causing it in general? Is there a fix available? | |
12-16-2009, 09:47 AM | #230 |
What noise are you guys talking about? The only noises I can think of are the beeping the radio makes when you press buttons, the hum of the fan on the ESC, and the slight sound the motors make. The radio beeping is probably fixable...but to my knowledge the other 2 aren't. I never really hear the fan on the ESC, but my cobalt motors are a lot louder than the stock motors. I don't mind the motors though.
12-16-2009, 01:05 PM | #231 |
If you watch my video http://www.youtube.com/watch?v=1F_FzaCmc10 you will here the constant whine when the throttle is applied and how annoying it can get. Maybe they don't all do it. I don't know, but mine is quite loud.:?
12-16-2009, 01:30 PM | #232 |
I just ran mine and it doesnt make that noise but I also switched to my DX3. So I dont know it that made a difference, I dont remember if it made noise before of not.
12-16-2009, 01:37 PM | #233 |
ohhh yeah. That noise...mine makes that a little bit, but my motors are on the loud side so it kinda drowns it out. I have no idea how to get rid of it, though.
12-16-2009, 03:43 PM | #234 |
Quick mod update! The CKRC high steering knuckles are awesome and help a ton for ground clearance alot, but to make if work right you need to order the Venom Creeper steering linkage kit to get the long link to clar the center of the diff housing. or bend a custom tie link.It moves the links up by almost a 1/4" and seem to not get hung up on anything anymore. Everything including bearings work in them. It also allows more steering angle which helps ALOT!!! Theres one more somewhat cheap upgrade that figured out to make the RS10 better and more durable!! Heres the links to what I have, Steering link set, http://www3.towerhobbies.com/cgi-bin...?&I=LXWJJ9&P=7 CKRC Knuckles http://www.ckrccrawlers.com/shop/ind...oducts_id=2379 |
12-16-2009, 11:10 PM | #235 |
Thats not the sound, Im talking about the beep between 4ws and all that. I dont wanna buy I new remote but im guessing I will have to dissect it.
12-17-2009, 08:32 AM | #236 |
Newbie Join Date: Nov 2009 Location: Farmington
will the stock esc handle a 7.4v 2 cell lipo stick pack like a 1/10 stadium style truck uses? I see some use a smaller lipo. I don't understand the difference between the two when they are both 7.4v. Maybe the bigger battery delivers more current?
12-17-2009, 01:32 PM | #237 |
Quarry Creeper Join Date: Dec 2009 Location: Brentwood
heres mine.. lowered body painted beadlocks on the way.. new HB Rovers 2.2 hitec hs-645mg servo CKRC steering knuckles.. |
12-17-2009, 01:36 PM | #238 |
Have I been talking to you over on RCU??
12-17-2009, 01:48 PM | #239 |
yea you have. seems like this is a better forum.. more people with rs10s..
12-17-2009, 01:50 PM | #240 |
Yes it is, theres a ton of info and good people here.
