01-19-2010, 09:48 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: GV
| 3S lipo?
can you run a 3s lipo witht the stock ESC???
01-19-2010, 10:54 PM | #2 |
Rock Stacker Join Date: Jan 2010 Location: moose lake
nope to much voltage.
01-20-2010, 06:38 AM | #3 |
Rock Crawler Join Date: Dec 2005 Location: Huntertown, In
I know theres a couple running a 2S 20C without issues. But your best best would be get a star and watch the classified section and pick up a used Rooster Crawler ESC or something similar. RC4WD has a good ESC for cheap too.
01-21-2010, 02:51 PM | #4 |
Quarry Creeper Join Date: Dec 2009 Location: Santa Cruz
I hooked mine up to my 3 cell 11.1 and it ran like a champ.I'm going to add a BEC and lipo cutoff to do it safely.I had an half an hour on the 11.1 and nothing fried
01-21-2010, 03:44 PM | #5 |
Newbie Join Date: Apr 2008 Location: scottdale
01-22-2010, 12:26 PM | #6 |
Newbie Join Date: Jan 2010 Location: Grass Valley
| receiver
Did you check the voltage running to your receiver on 11.1?
12-11-2010, 10:54 PM | #7 |
Newbie Join Date: Nov 2010 Location: Spartanburg
Isnt a rooster crawler esc only rated to hold a 2s Lipo? I would also like to run a 3s Lipo so interested in ideas.
12-12-2010, 07:42 AM | #8 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
Yep, it's only rated for a 2s lipo. There are people who use 3s on it, but if you chance it you should be prepared for the ESC to not survive. You might have great luck and it work fine, then again you might kill the ESC right away, it's a gamble.
12-12-2010, 07:58 AM | #9 |
Newbie Join Date: Nov 2010 Location: Folsom
| i've been running 3s on my rooster and love it. No boom yet and it's got some good miles on it. This is probably a myth as I've never heard from all those who run 3s that theirs actually fried.
12-12-2010, 02:46 PM | #10 |
It certainly could be a myth. I've seen plenty of people on here who use 3s on the rooster crawlers. I probably would too if I had that setup, but I do like to point out to folks if things are only rated for a certain voltage. I can see someone frying an ESC, then getting pissed because someone told them it could handle more.
12-13-2010, 11:48 AM | #11 |
Pebble Pounder Join Date: Apr 2010 Location: Brighton, MI
I ran 3s on my stock esc for a few months with a low volt buzzer. Fan runs too fast so you'll have to modify the power supply for that but the esc held up. The receiver still only got 4.8 volts, so it won't help your servos any, but gives you soooo much more power.
01-04-2011, 09:49 AM | #12 |
Anyone run 3s on a stock nightcrawler? I probably wont try till I am ready to buy a new esc
01-04-2011, 10:05 AM | #13 |
01-05-2011, 08:49 AM | #14 |
Awesome thanks.
01-06-2011, 08:50 PM | #15 |
Newbie Join Date: Oct 2009 Location: socal
check electronics section i have heard of people doin it but id be alil worried myself i run 2s no problem tho
01-06-2011, 11:40 PM | #16 |
Rock Crawler Join Date: Dec 2010 Location: Beaumont Tx!
just search there is like 20 threads about it already.
01-08-2011, 04:04 PM | #17 | |
Newbie Join Date: Dec 2010 Location: newcastle
How do the stock motors hold up..? Did modify your power the the fan or will it to ok running fast? | |
02-17-2011, 07:18 PM | #18 |
Pebble Pounder Join Date: Jan 2011 Location: Deltona Fl.
found out the hard way today......3s bought used with the deans wired rev polarity....poof! no mo stock ESC!
02-17-2011, 11:38 PM | #19 |
Rock Crawler Join Date: Feb 2010 Location: Sturgis
Yes it will work but for how long is the million dollar ? And I think rooster makes a 2s and 3s esc seperatly.
02-18-2011, 02:36 AM | #20 |
So far my stock esc is holding up to the 3S the fan on it only lasted 30 seconds so i have taken that of and run it without and it seems to be only warm not hot at all after a constant battering and a hole 2200 pack the motors on the other hand are getting hot once its been stalled to much as expected with that many volts. I will upgrade when i have the cash still.
