03-24-2011, 07:04 PM | #21 |
Quarry Creeper Join Date: Oct 2010 Location: Paragould
got my aluminum 12mm hex nuts in today to replace the striped plastic ones (thank you RPP) drives with all 4 wheels now |
03-24-2011, 09:19 PM | #22 |
Hooray!
03-25-2011, 08:25 AM | #23 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
whats your wheelbase it looks kinda long
03-25-2011, 08:40 AM | #24 |
13" i can go to 12.5" it is long now i have the links all the way out for playing i can bring them in to the right length plus i am getting longer upper's to help with drive shaft angle |
03-25-2011, 11:25 AM | #25 | |
Get your wheelbase right, then see how it sits. | |
08-20-2011, 08:18 PM | #26 |
been a while since a update i broke the tranny so i just got my new one in . .had Duuuuuuuude help shorten and reorganize my wiring for it would look better . .started to cut some panels and changed the front around and added some wight . .................................................. ...................................... .tranny all greased up.......... . . new home bent lowers . new tranny . . . |
08-20-2011, 08:24 PM | #27 |
hooray! |
08-20-2011, 08:50 PM | #28 |
ya for real i need to go play now lol . . . .i do want to come up with a better front plate the front links are to low and is making more TT then i had with the other small plate but that will come in time i will run some ideas to get the links up some |
08-22-2011, 08:30 AM | #29 |
Rock Stacker Join Date: Aug 2011 Location: murrieta
so how many exceed parts do you have left on it.
08-22-2011, 01:34 PM | #30 |
| half and half |
09-04-2011, 12:25 PM | #31 |
someone tossed a grande at my rig teaser pic can you guess what is about to happen? changing things up a bit more updates in a few............................and i will have to change the name now |
09-04-2011, 06:29 PM | #32 |
thats right the max stone/axial is now MOA more to come half and half to be used on a new project roller MOA gut-less for the MOA Haters |
09-04-2011, 08:29 PM | #33 |
Loser. What are those axles from? |
09-04-2011, 08:41 PM | #34 |
| lol homie they are rs10 i have the stock rs10 electronics (and it sucks) on it right now but i will be putting 2 esc's on there and run 3s with 35t motors now i am going to build a more scale'r like trail rig with my other axles |
09-04-2011, 08:43 PM | #35 |
| Why don't we just rewire that RC4WD esc back to the dual motor setup? Or will it not handle 3s?
09-04-2011, 08:46 PM | #36 | |
ya that would work till i get my other rig going then i can see what my options from there. if we could do that i am up for it. just tell me when to come over i am free everyday after noon need to chat with you about my trail rig too i need your input to see if it works | |
09-12-2011, 05:59 PM | #37 |
well i got my outcry esc wired up and running 3s 2200 lipos on my NOW moa axles . . . went out sunday for some crawling with Duuuuuuuude!! and Dakota and this thing ran so great only problem i was having was the front was way to light i had no wight on it. so i got home happy with it and decided to finaly put some skins and few other things on it new skins . new steel hex's so i dont strip out any thing like my new rims (thanks Duuuuuuude!!!!) new rims painting the rings now more to follow |
09-12-2011, 07:46 PM | #38 |
OK brake down of what i am running now................................... frogger chassis (love it) rover's (white) burg- rims exceed- links, shocks, servo, tx-rx, cut body axial- skid,steel hex's redcat- motors, axles out-cry esc w/bec, novak lipo cutoff G-force 2200 3s lipo's home made upper 4 link mount deans Last edited by jokers_toys; 09-12-2011 at 07:47 PM. Reason: add |
09-12-2011, 08:38 PM | #39 |
Did I ever mention that you need to drop your ride height a bit? If not, you need to drop your ride height a bit. |
09-12-2011, 09:10 PM | #40 |
