01-06-2012, 04:34 PM | #1 |
Pebble Pounder Join Date: Nov 2011 Location: Maricopa
| Clocking Axles
Tell me if I have this right..... The gearbox is at 0 deg.. clocking it 20 deg. you would rotate the axle in (motor closer to the ground)? If it is the other way, doesn't that hang up and/or put more stress on the steering links? What is the maximum amout you want to go or not go over? Should both the front and rear be clocked the same amount? |
01-06-2012, 05:34 PM | #2 |
Pebble Pounder Join Date: Nov 2011 Location: raceland
| Re: Clocking Axles
i clocked mine about 15deg. in the front and i didnt move the rear so far working out pretty good.
01-06-2012, 06:19 PM | #3 |
Pebble Pounder Join Date: Oct 2011 Location: Meridian
| Re: Clocking Axles
I thought Clocking was just to relieve the pressure on the U joints. (Shafty) How does this benefit MOA rigs?
01-06-2012, 09:05 PM | #4 |
| Re: Clocking Axles |
01-06-2012, 09:12 PM | #5 |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
| Re: Clocking Axles
Clocking the front axle back has 2 advantages. The first, and easiest to see, is that the heavy motor sits lower, bringing down your center of gravity. (Fellow 540 club members take note). Next, is the unique steering quality it creates. It gives the wheels a slight caster when steering. You know when you drive up to a vertical wall with your steering at full throw? The front of the tires make you go straight up. only the BOTTOM of the tires have steering. As you can see bellow, steering caster leans the tires over a bit, giving you steering even when approaching a vertical climb with the front-most of the tire. |
01-06-2012, 09:59 PM | #6 |
| Re: Clocking Axles Quote: AWESOME, thanks dude, I appreciate the info!! I know exactly what you mean about a going up a wall, and the rig went straight up. I have 25 deg. on the front and 20 on the rear. Should I keep the rear clocked or level it back out? |
01-06-2012, 11:08 PM | #7 |
| Re: Clocking Axles
Might as well keep the back too. keeps the weight nice and low. try this test; with the 4wsteer on, turn the knob and see how the chassis rocks side to side. If you can live with that while crawling, keep it! Mine is clocked about 16 degrees front and 9 degrees rear. but thats more for link clearance front, and underbelly clearance at the back. I'm aiming for 20 up front again, like when that picture was taken. |
01-07-2012, 01:48 AM | #8 | |
Dude, now that you mention it..... I use that to "wiggle" the rig coming down steep angles over rock or whatever. It works good for when I don't trust myself with a smooth trigger finger. | |
01-07-2012, 02:13 AM | #9 |
Rock Stacker Join Date: Jan 2012 Location: East stroudsburg
| Re: Clocking Axles
Hahaha that wiggle has saved me a few times
01-07-2012, 07:01 PM | #10 |
| Re: Clocking Axles
Sweet, I'ma do it! thanks for the info Jackalope.
01-11-2012, 06:30 AM | #11 |
Newbie Join Date: Dec 2011 Location: croton
| Re: Clocking Axles
Great idea. Clocking mine tonight!!!!
Clocking Axles - Similar Threads | ||||
Clocking Clod axles? | ToTheMAXXcrawler | Tamiya Clod Buster | 4 | 06-26-2010 10:36 PM |
Whats Clocking your axles??? | cmacclel | XTM Crawler | 3 | 08-16-2009 04:16 PM |
clocking axles | legion1capone | Newbie General | 1 | 03-24-2009 02:33 PM |
Clocking the axles. | hakmazter | Newbie General | 2 | 10-08-2008 02:11 AM |
