03-18-2012, 06:07 PM | #1 |
Newbie Join Date: Mar 2012 Location: Lambertville
| RS10 ESC Tekin Fx-R problem?
Ok so i am a noob to these new Tekin FX-R ESC's, Here's my problem, I soldered in my new Tekin FX-R, Wired everything correctly with the capacitor. first try it would "jump" when i throttled it. Now it jumps when i go in reverse? And only after i stop completely. and hit the trigger six times then it might go in reverse. So reset or calibrated it with the mode button. Still having issues with reverse! Sometimes have to wait a few seconds before it will actually move in reverse. Still using stock reciever and controller. stock motors on 3s Lipos Love em by the way. Also on my first run today..... truck took off after i ran it fine for a few minutes. Just shotoff going on its own? Turned everything off and back on and was working fine except the reverse thing. Hoping someone had some input on this weird problem. I just ordered the hotwire programmer. By the way stock motors on stock reciever, with only one FX-R ESC. No dig switch. Thanks in advance for your input! |
03-18-2012, 08:18 PM | #2 |
Rock Stacker Join Date: Dec 2010 Location: San Anselmo, Ca
| Re: RS10 ESC Tekin Fx-R problem?
To get rid of the reverse delay, that's in the programming of your fxr. Check your manual it will tell you how to get rid of the reverse delay. If you don't have a manual check there web site. You should be able to do this without the hotwire. It will be under your reverse options. Last edited by CrAsHmAsTeR; 03-18-2012 at 08:25 PM. |
RS10 ESC Tekin Fx-R problem? - Similar Threads | ||||
Problem with Tekin RS system in my LCC, will a BEC fix my problem? | rcboy514 | Electronics | 3 | 01-12-2012 05:55 PM |
RS10 problem | MiddleT | Redcat Crawlers | 5 | 03-02-2011 01:36 PM |
problem with rs10 esc or tx/rx? | fast_eddie_86 | Redcat Crawlers | 13 | 09-10-2010 02:35 PM |
New Rs10 problem (maybe) | tbutkus | Redcat Crawlers | 10 | 02-03-2010 12:33 PM |
Problem with Tekin fxr esc | HELLSUNICORN | Electronics | 16 | 05-12-2009 12:18 AM |
