01-13-2013, 07:00 PM | #1 |
Newbie Join Date: Sep 2012 Location: Northeast AR
| First mods/upgrades?
So I just got my cat a few days ago off craigslist. It came with proline hammers and a hpi servo up front and a hitec in the rear. The rear servo isn't hooked up because I have no servo arm for it and the link is attached to the servo directly until I get a new arm. What are some key upgrades or needed mods for the cat that help it out the most? I know that I will get some rovers later but the hammers are handling everything fine for now. Any advice will help. Also new servo suggestions. Thanks
01-13-2013, 07:26 PM | #2 |
RCC Addict Join Date: Dec 2011 Location: Australia Queensland!
| Re: First mods/upgrades?
First do a quick search 'rs10 mods' or something like that and have a look through people threads not mine.... as they will show the first mods ect they have done. A little research will go a long way with the rs10 as most do the same mods. But a decent cheap servo would be a ckrc 208oz, crawford 208oz or a tower pro 208oz they are all the same metal gears have decent torque and are about $20. |
01-13-2013, 07:32 PM | #3 |
Will all servos bolt right up in place with no modifications?
01-13-2013, 07:34 PM | #4 |
All standard size servos will other size servo will normally say whether they are 1:8 or mini ect.
01-13-2013, 09:12 PM | #5 |
Would it be a good idea to get aluminum servo arms or do they ever break?
01-13-2013, 09:28 PM | #6 |
Rock Stacker Join Date: Jan 2011 Location: michigan
Yes get the alum sero arm,they are like $i8 shipped on ebay.If i were you i would put that hitec up front and the hpi in the rear,it a better servo.Metal gears are a nice cheap upgrade.I have never used the tires your running,but i do like both hot bodies tires(roveres and sedonas)other than that get that bad boy on a pile and enjoy.
01-13-2013, 11:17 PM | #7 |
Quarry Creeper Join Date: Oct 2012 Location: Cashmere (central WA)
Most people replace the spurr gear pin before they brake and chew up gears
01-14-2013, 04:25 AM | #8 | |
| Re: First mods/upgrades? Quote:
01-14-2013, 04:27 AM | #9 |
| Re: First mods/upgrades? |
01-14-2013, 05:43 PM | #10 |
Rock Stacker Join Date: Nov 2012 Location: USA Ga.
First thing I did was to replace the dif pins and remove the foam from my tires. Just replaced my servos today with towerpro mg945 s and put some led's on it just in case I decided to go night crawling
01-15-2013, 10:06 AM | #11 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
Which hitec servo is installed? Hitec makes some nicer servos, so it's tough to recommend something without knowing what you have. The proline hammers are decent tires, so stick with those and see how you like them. If they don't do well on your local terrain, you can look into upgrades. Taking care of little things like the diff pin are good, easy fixes. If you're content not having rear steer, you could go ahead and remove the rear servo and lock out the rear steer. Other cheap things you can do is tinker with the setup and try to understand what those changes make to the truck. If you tinker with the setup, try making one change at a time and see if it helps or hinders it. Aside from that, just drive the truck and replace things as you see fit, or as they need it. One hugely beneficial upgrade you could make, assuming you're still using the stock battery/charger, is to invest in a good charger and some lipos. |
01-16-2013, 11:37 AM | #12 |
Has anyone had any luck with a dig system? Can u lock the rear steer and use that channel?
01-17-2013, 01:09 PM | #13 |
| Re: First mods/upgrades? There was a thread a while back about using dig with the stock radio, but if I recall correctly it required a fair bit of modding to work. I used a dig setup for a while with a modded traxxas tq3 radio and it worked well.
01-17-2013, 01:24 PM | #14 |
good video on how: [-TUTORIAL-] Rear Dig Mod on Redcat Rockslide RS10 XT (Cheap!) - YouTube |
01-17-2013, 03:17 PM | #15 |
Pebble Pounder Join Date: Jan 2013 Location: Fall River
Servos are the biggest weak link in the truck so you already have that covered. Hardened gear pin (and steel gears if you gonna be in the tranny anyway) would be good. Some bent links will help you clear the rocks better. I'm thinking of upgrading the stock esc to a Novak m2 soon
01-17-2013, 04:49 PM | #16 |
If yoyr a little crafty a homemade chassis and links are the way to go. I just done mine and the clearence now is amazing.
01-17-2013, 08:44 PM | #17 | |
01-17-2013, 08:46 PM | #18 |
01-19-2013, 06:29 PM | #19 |
reaseach is your friend being spoon fed is not a good idea |
01-19-2013, 08:41 PM | #20 |
First mods/upgrades? - Similar Threads | ||||
CR-01 Upgrades/mods | Giznad | Tamiya CR-01 | 11 | 03-18-2013 09:31 AM |
Essential mods and upgrades? | Jigs | Axial Wraith | 3 | 12-10-2012 07:59 PM |
Transmission upgrades/mods | Duxx | Tamiya CR-01 | 1 | 01-26-2012 08:52 AM |
SCX10 Axle Upgrades/ Mods | Montana Mike | Newbie General | 7 | 02-02-2011 09:40 PM |
Newbie Mods and Upgrades | BrokenBooks | Duratrax Cliff Climber | 7 | 04-30-2009 06:39 AM |
