Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Rods, I should of just built my own from scratch
Old 10-17-2013, 08:44 PM   #21
Default Re: Rods, I should of just built my own from scratch
as for the wheel hexes, If you superglue the hexes into the plastic wheels (forget bout the grub screw) it fills in the extra space and mine are good for about 3 or 4 months before I need to touch em up. That'll let ya keep the stock wheels for a little longer.
The Jackalope is offline   Reply With Quote
Old 10-20-2013, 05:20 PM   #22
Took my crawler for a quick spin on the rocks this morning, I managed to wear through the front pinions again or maybe its just slipping on the motor shaft as it was still turning but had no power. at the same time the pinion gave it also snapped a ball joint. This was the first time I tried it with both front and rear links on and it was going great. That little extra reach to get the tyre on top of the next rock helped so much.
AusRod is offline   Reply With Quote
Old 11-03-2013, 04:12 AM   #23
So i got tiered of my redcat axles and ordered a set of Super Bully axles from RC4wd, I have started modelling them and plan to build my own crawler from the axles up over the next month or so. I need to look up the rules so i can design something that complies. I will also be able to make the rockslide almost stock again so i can go crawling with my misses.
Old 11-06-2013, 11:26 PM   #24
I got my CNC mill running so i had to try it out with roadrunner on the back window
Old 11-21-2013, 09:17 PM   #25
And so have you built the axles yet?
madmic is offline   Reply With Quote
Old 11-24-2013, 02:39 AM   #26
I have been wanting to build a Super for a while now and designed a chassis which i attempted to make today. Unfortunately me cutting technique isn't up to par and the rear end of it got hot and separated the carbon layers so i plan to trim the ends down and use this chassis for my redcat.
So after 2 end mills and a very blunt drill (I need to invest in some good quality tools), one side of the chassis was cut out.
I think it will suit the redcat well once i trim the ends down a bit
Old 12-14-2013, 06:21 PM   #27
Been busy at work and havent had time do play with my crawler, today i finally got a chance to cut out a servo mount for my bully axles. Once i try these out there is a fair amount of material that i can take out of the base.
Old 12-15-2013, 03:09 AM   #28
Mate you might want to post this in the bully section as it is not a rs10 anymore.
pajey is offline   Reply With Quote
Rods, I should of just built my own from scratch - Similar Threads
Another scratch built JK rottenbelly 1.9 Scale Rigs 36 11-14-2011 05:46 PM
Scratch built rag6 Newbie General 2 06-30-2011 07:50 AM
Scratch Built Bumper wes81 General Scale Talk 15 10-21-2010 03:41 PM
Scale ROD Crawler - It's built from rods!! keiseng79 2.2 Scale Rigs 176 11-09-2008 07:22 AM
Scratch built 2.2 Kamikaze Tamiya Clod Buster 26 09-11-2007 07:51 PM
