12-16-2015, 07:01 PM | #1 |
Newbie Join Date: Dec 2015 Location: Santa Rosa
| Front wheels won't drive under load
Front wheels drive until they come under a load like going over obstacles then they stop driving. gearbox?
12-16-2015, 08:07 PM | #2 |
RCC Addict Join Date: May 2011 Location: at home
| Re: Front wheels won't drive under load
have to ask this - is the battery fully charged? have you checked the battery to make sure you have full voltage as in no bad cells? you have a serious case of 'clod stall' |
12-17-2015, 10:49 AM | #3 |
Battery charged. When the car is off and I spin the front wheels, there is no resistance.
12-17-2015, 11:10 AM | #4 |
Search the term Clod Stall
12-17-2015, 11:43 AM | #5 |
do the front wheels spin very freely? check the pinion, maybe it has come loose. you should feel some resistance when spinning the wheels. |
12-17-2015, 02:37 PM | #6 |
Rock Stacker Join Date: May 2015 Location: Saint Louis, MO
probably sheared the pin(RCT-H018 ) in the diff, or it spun and tore up the plate(RCT-P005) behind it. See diagram at bottom left of page Rockslide10 Last edited by gman350; 12-17-2015 at 04:16 PM. |
12-17-2015, 03:03 PM | #7 |
that is a good picture to save, has the part numbers and shows how everything fits together good one gman, good call on what might be wrong too. |
12-17-2015, 04:22 PM | #8 |
What's sad is that you can't buy just that plate by itself. You have to buy the whole spur gear assembly RCT-T006 or a set of gears RCT-P005 No one makes an aluminum replacement either. I'll bet I have at least 6 spare spur gear sets I bought to use the plate before I got pissed off and made my own. |
12-17-2015, 06:48 PM | #9 |
Thank you all. I will check it out and let you know
12-17-2015, 07:01 PM | #10 |
Quarry Creeper Join Date: Aug 2015 Location: canton,oh
we have been using needle bearings from a u joint we had laying around . ours happens to be for a truck or something so we have to cut needle bearing to length and drill out center shaft not a big deal takes longer to get to than to fab. i suspect we will start tearing up the plast ic next but hasnt happened yet. we tried using hub pins but they were just as week. Last edited by jamesthe1v; 12-17-2015 at 07:03 PM. |
12-18-2015, 12:15 PM | #11 |
No. There is a little resistance, but not like it should be.
12-18-2015, 01:56 PM | #12 |
have you opened up the housing yet? either the pin/backing plate as gman suggested or the pinion. sometimes you can find complete axle with motor on ebay though right now they only have them without motors but at 25 to 30 each. |
01-18-2016, 07:49 PM | #13 |
| Re: Front wheels won't drive under load |
02-18-2016, 04:21 PM | #14 |
Rock Stacker Join Date: Jan 2011 Location: Travelers Rest
Ok , I just got a rs-10 for my son opened up the box this morning , charged it up and he played with it when he got home from school for about 10 minutes before the front wheels stopped turning . You can give it throttle and see the motor is spinning but the wheels don't ... Could this be the drive pins ? wnat are he chances I tore the other parts mentioned as well?
02-18-2016, 05:29 PM | #15 |
could be several things. the pin is the most likely but there is a chance that the motor might be loose enough to have disengaged from the first gear. easy to check, just pull the cover and see if the gears turn when you apply power. cannot stress enough to check all screws on any vehicle. |
Front wheels won't drive under load - Similar Threads | ||||
Front drive shaft | Wendtskie | Axial SCX-10 | 5 | 11-10-2013 04:27 PM |
Over drive front or Under drive rear? | o0wiz0o | Axial SCX-10 | 14 | 04-29-2013 01:25 PM |
Only front wheel drive? | Slowrunner | Newbie General | 0 | 01-01-2010 03:33 PM |
Help on front wheel drive!!!! | speedcrawler | Losi Mini-Rock Crawler | 5 | 06-14-2009 06:55 AM |
