Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Redcat beadlock ring pattern
Old 02-09-2019, 07:24 AM   #1
Default Redcat beadlock ring pattern
Has anyone or can anyone check the beadlock ring pattern against some of the other brand out there? See if we can use locked up, axial, VP, etc rings? I tried motoworx, it doesn't work.
DukeMinnix is offline   Reply With Quote
Old 02-09-2019, 07:34 AM   #2
Default Re: Redcat beadlock ring pattern
I've used rings off of Incision and Axial wheels and they worked fine.
Sent from my Pixel 2 using Tapatalk
brimdogg is offline   Reply With Quote
Old 02-09-2019, 08:01 AM   #3
That opens up the axial/incision compatible locked up rings too, awesome.
Old 02-09-2019, 09:30 AM   #4
You didn't specify which Redcat crawler, but I use Redcat RS10XT beadlock rings on Axial wheels just fine.
Sent from my Pixel using Tapatalk
Damatheus is offline   Reply With Quote
Redcat beadlock ring pattern - Similar Threads
Wheels with axial 1.9 6 bolt beadlock pattern? Grandbuggy Tires and Wheels 6 03-30-2017 01:02 PM
10 hole beadlock pattern crawler105 Tires and Wheels 1 06-03-2014 02:50 PM
Axial ax10 2.2 beadlock pattern? Goatsniper Tools, and Procedures 4 06-03-2014 01:06 PM
proline 8 shooter ring bolt pattern? idk Tires and Wheels 0 05-24-2013 01:59 PM
Beadlock ring?? Blasto0341 General Crawlers 6 01-05-2013 09:31 PM
