04-23-2019, 09:56 AM | #21 |
Newbie Join Date: Oct 2018 Location: east hampton
| Re: Need some gen8 dimensions I'd be happy to send you a kit, or direct you to the link for download if you have a 3d printer that will print ninjaflex... if you would like a kit sent to you for testing just PM me your address....
04-23-2019, 01:16 PM | #22 | |
| Re: Need some gen8 dimensions Quote:
i totaly get what your saying and i completly see why your doing it and it has its place but i would rather spend $20 on driveshafts then try to save the stock shafts and im gona be replacing bearigs anyway thats just me though | |
04-23-2019, 11:34 PM | #23 |
I like some intellectual conversation, I'm always game.. I appriciate your opinion, and always respect my elders.. I'm sorry you had a stroke and had to stop some of the things you are passionate about..that being said I'd like to touch on some sections of your reply... first though let's find common ground if we could about the redcat gen 7 and gen 8... as you have stated these machines put out low amounts of torque and power.. they can easily be stalled in the right situation and with your hands.. and respectively they run extremely slow... agreed? That being said, I beleive your "new" bearing explosion failure was definitely on something with substantial rpm.. my guess would be not on a low torque low power gen 7 or 8... While talking about low power/torque I think we could both agree a stock gen 7 or 8 will not shear a pin from the u joint, nor would it tear the pin bosses into oblong holes.. it will stall the can... while you have sheared one as well as I, it was in machines with a substantial amount more power... I have successfully murdered 2 sets of shafts in one week in a mud hole with fine silt in it...you could physically see the debris form a paste similar to lapping compound.. this is and was the culprit... with boots installed I have months of that same pit under its belt with very minimal wear... I'm well aware of different steels but this is not a metallurgy conversation.. no doubt there are better shaft options.. but even those need to be rebuilt from wear.. goal here is to use 6.00 shafts and get plenty of enjoyment even in the nastiest of mud to the roof... Now onto real life engines.. I'm with you.. I've built many many engines.. more than I could ever count including 9 and 10 second drag engines that you can go get milk at the grocery store with... everything from roots blowers to pro chargers to turbos.. literally thousands of engines.. I also actively cad/cam and cnc parts, as well as successfully modified and sold nitro engines all over the world in the past.. with all that being said as you did, does it really matter how old we are and what we have done? Not really... it doesnt make sand in an engine a good idea.. and as a side note most engineers have never ever been in the field hands on... let me remind you that NASA engineers fail daily, repetitively, and the guys that are hands on get to tell them get back to drawing pictures... this again holds no wieght at all... Ok so you pour sand in an engine valve cover for break in.. but the filter catches the sand as you stated so what's it doing? You see how this is a contradiction correct? 1 of 2 things will happen...1 the oil from the lifters/pushrods will carry the sand to the lifter valley, said valley drains off on each end of the block, also onto the cam.. cam lobes and lifters are then scarred to death with sand granuals before returning to the pan to be pumped into the filter.. what is gained from scars on the lobe and lifter? That's sounds like a lifter not taking in the making... lol it rhymes... Scenario 2, the sand is carried to the end valley returns and returned to the pan, then to the filter to catch it... what was gained for break in? Besides not scarring the crap out of the lobes and lifters... Now what I have seen from professional engine builders of the old days they used bon am or borax and made a light paste... they would rub the cylinders with the paste after the piston was installed.. this aided in ring break in.. this actually serves a purpose, or did... with the constant change in engine building the hone degree was dialed in as well as ring metallurgy, eliminating the need of break in aids... I implore you to talk to any machine shop, professinal engine builder, manufacturer, gm, chrysler, ford, honda, etc. in the world, ask them if a handful of sand is a good idea for engine break in.. remember, engines have air filters for a reason.. because rings, valve seats/guides and cylinders dont like dirt/ sand...it wears metal no matter what... Thank you for seeing a need for the boots, and I appriciate that they aren't for you, but please please please dont dismiss facts of true failure circumstances.... and please keep the sand in your own engines....lol.. thanks for reading... |
04-25-2019, 08:22 AM | #24 | |
the bearings exploding is on crawlers my wraith eats them i can explode bearings at will i my 1/8 scale trucks also eat bearings they to will explode bearings and snap shafts with just a blip of the throtle why worrie about bearings when im already ordering them by the tube the sand is extremely fine sand its the sand you find 8n your intake after a day out in the sand dunes it more resembles polishing compound than playground sand so theres no gouging going on and gets flushed out but every one knows loose motors make better horese power so when thats your goal it makes sence there not neerly as reliable but hay and besides out here theres no way to keep it out of anything so it gona happen and honestly i dont see a differance between the borax and sand seeing as how borax is just a soft sand so different substance but same theory he liked to loosen up the valve train and it helps mate the push rods in there cups the cam lobs just get a nice polishing because the cam shaft is again hardend steel and sand wont hurt it becaus its soft fine sand i mean dude how much metal gets flushed out in the oil during break in thats way more a issue than the sand and it still happens today all engines need break in most companys do that before the vehicle hits the lots hence why they all have a few miles on them also they already did the break in the last new car i had had break i instructions in the manual so the dealers still see the need on the other hand i know a old guy who seas drive it like you stole it right from the get go and i have seen no ill affects just change the oil alot the last time i went to a dealer i had to school them on how to put a 5" lift on a subaru wagon and were i got the bumpers and tube fenders and snorkle then explain how i got a extra 50hp out of that turd of a engine when there are absolutly no performance parts available for that engine of any kind or any kind of aftermarket even the subaru gurus are like what how heres a short vid of my last build in the mud hole ttps://youtu.be/IXxKtU2hIAc they offered me a job they sead they just wanted my rig parked in front of there shop lol needless to say i would never try to get advice from a keyboard jockey with a wrench or more cominly known these days as a automotive technition all they know how to do is replace parts that the computer tells them is broken try geting someone to work on a air cooled engine the dealer wouldent even know were to star they be like standing infront of tbe car with the hood up asking weres the motor ya its that bad the simplest motor ever made and they wont work on it because it dosent have a diognotic port the engineer from nasa failed daily because we dident have cad or computer modoling or cnc machines everything was made by a person and tested then re made then tested and sometimes redesigned thats how we did it before windows was a computer thing im the type of guy who will grab a file and whittle down custom parts as far as my health its cool im a grown man i can take anything now the poo has hit the fan all thats left to do now is deal and i got real lucky and mostly recovered but because i turned a wrench for so long my hands are shot and thats the most frustrating of all especialy hard when working on toy trucks as far as the toy trucks go i dont have a g7 but i do have the e10 its going on 4 years now i havent touched the front axle at all not op3ned it up for nothing i did replace the bearings in the rear axle like 2 years ago and th3 trans cracked in half and got replaced the new trans had new bearings i replaced the shafts the firs5 week wi5h $12 chinese drive shafts and they have been beat on for 4 years now with no signs of ware i put the e10 shafts on another rig and snap not even a full run the gen8 will.be getting a.set of.$20 gds driveshafts there no mips but ive had good luck with them ill never have to replace them and they dont need any maintinance till the pin breaks then just replace the pin i dont see any reason to run a part that i know is gona fail at the worst time let alone replace sead part with the same part once you bought 2 stock shafts your at the price of a cheap aftermarket set so back to the original point lol otters oh wait i dident have a point originaly lol | |
Need some gen8 dimensions - Similar Threads | ||||
My gen8 | 00Pocho | Redcat Crawlers | 27 | 04-18-2019 04:31 PM |
Gen8 Builds!? | SIK_BOY | Redcat Crawlers | 6 | 02-19-2019 07:00 AM |
First video of my Gen8 | FunkMasterFlex | Redcat Crawlers | 5 | 02-01-2019 07:42 AM |
Gen8 manual is up. Here's what we know | Jim85IROC | Redcat Crawlers | 16 | 12-28-2018 02:13 PM |
Gen8 ?? | Frank211 | Chit Chat | 5 | 12-04-2018 04:24 AM |
