02-18-2020, 10:14 AM | #1 |
Rock Stacker Join Date: Dec 2019 Location: St-Jean - Quebec
| Installing an Integy cage on my Everest 10
I started the installation yesterday. I'm using plastic sheets to make my battery tray. I'll be using the same material to make the side panels but in a darker orange. Sent from my SM-A530W using Tapatalk |
02-18-2020, 05:15 PM | #2 |
| Re: Installing an Integy cage on my Everest 10
those are cool cages they go good with the ax10/e10 in my opinion you should toss the springs on the shocks and run a droop suspention set up then take the foams out of the tires till you upgrade them that rig will perform alot better |
02-19-2020, 07:39 PM | #3 |
Here are some more pictures. I swapped the tires for the Injora 2.2 I can fit a 2200mah 2s lipo no problem. Sent from my SM-A530W using Tapatalk |
Installing an Integy cage on my Everest 10 - Similar Threads | ||||
Integy cage build. | drjones1981 | Axial SCX-10 | 45 | 10-16-2015 01:31 PM |
installing integy EXT +15mm alxeand wheel hub | desertdude | Axial SCX-10 | 0 | 08-16-2011 09:56 AM |
Integy cage | jado6006 | Axial AX-10 Scorpion | 5 | 03-03-2011 05:54 PM |
integy 2.2 cage | ninetwofiveRC | Venom Creeper | 7 | 01-03-2011 03:42 PM |
Integy Cage | nightcrawler86 | Losi Mini-Rock Crawler | 8 | 05-19-2009 09:26 AM |
